Max overbore on a 292 - Ford Truck Enthusiasts Forums
Old 10-19-2013, 09:00 PM
69supercj 69supercj is offline
69supercj is starting off with a positive reputation.
I've got a 292 that is already 50 over. Whats the max safe over bore? Also my crank is 20 on the rods and 10 on the mains, whats the most you can safely turn one of these?
Old 10-19-2013, 11:16 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
This guy sells .060 pistons, not sure your motor will clean up with only another .010.
Rod and mains out to .040.
Price Sheet
I remember my dad going on and on about a neighbor's Minneapolis Moline tractor motor have a rod journal turned .120, as he ran it pounding away for quite some time before the overhaul. So, sometimes you can go more than you think!!!
This is an old article, but it says you can go .125 on overbore.
http://www.oocities.org/yblockhead/HotRodding292.html
More of the same, different author it appears, or not...again, old article:
http://www.oocities.org/yblockhead/Y...fications.html
More recent article, 2009, again, talks .120 overbore:
http://www.rodandcustommagazine.com/tipstricks/74739/
Old 10-21-2013, 02:56 PM
312 312 is offline
312 is starting off with a positive reputation.
if its .050 over that's a stnd,312 piston bore.just buy a .030 or .040 312 piston enough to clean it up.
Safe EGT Temp jcalebw 6.0L Power Stroke Diesel 12 02-08-2014 11:44 AM
Maximum safe overbore for a 292 block 69supercj 1961 - 1966 F-100 & Larger F-Series Trucks 1 10-21-2013 11:27 AM
What is the max bore size for a 272 Rmc292 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 09-11-2013 09:37 PM
Max safe bore on 352 block? wagonerkl FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 09-01-2010 01:03 AM
Max tire size on a 2 inch lift? tkiner 1999 to 2016 Super Duty 4 03-15-2010 12:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
