1995 Lightning intake phenolic spacer - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 10-19-2013, 08:45 PM
mustang4life1985's Avatar
mustang4life1985 mustang4life1985 is offline
mustang4life1985 is starting off with a positive reputation.
Does anyone have any info about a phenolic spacer for the Lightning intake? I just recently purchased a 95 and it has a spacer below the upper intake.
Old 10-20-2013, 07:07 PM
BlackHD06 BlackHD06 is offline
BlackHD06 is starting off with a positive reputation.
what do you want to know about it?
its not stock. any gt40 spacer works, most guys run them when they want to put aftermarket valve covers on the truck.
Old 10-20-2013, 10:31 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
^ Agreed. They're mainly used to gain a little extra clearance between the upper and lower intakes so taller valve covers may be used. However, the hot exhaust gases may burn a hole through it, over time, if the EGR port in the lower intake hasn't been plugged.
Old 10-21-2013, 07:52 AM
Thanks for the info guys!
Phenolic spacer for 1904 Santiagoeford 1961 - 1966 F-100 & Larger F-Series Trucks 3 09-18-2015 04:06 PM
Vacuum port? Can I make one? 91Fbody 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-18-2015 12:51 AM
Where to find Phenolic Spacer Plate Victor L 1967 - 1972 F-100 & Larger F-Series Trucks 23 01-02-2015 11:18 AM
Phenolic spacer ? boaterbob Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 02-02-2013 01:03 PM
Phenolic Intake Manifold Spacer cbzdel Modular V10 (6.8l) 6 05-07-2012 11:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
