Fuel lines anything special?
The problem with using standard 30R9 fuel injection hose in the valley of the engine is HEAT. All hose will soften when exposed to high ambient temps.
30R9 hose is rated -29F to 275F with a max operating pressure of 100F
The blue OEM hose is -40F to 302F with a max operating press of 300psi
The higher temp rating along with much higher pressure rating will effect the longevity of the hose in our application.
And yes, use fuel injection hose clamps, not worm-gear clamps.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzleguzzle's Mods & Maintenance website
It can. Age and usage are the main cause. They're getting close to 20 yrs old. Do you notice any tiny oring particles in the fuel bowl along with being black?
snakedoc
08-17-2011 10:30 PM
