its begun
Old 10-27-2013, 01:47 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
so should i return it ? and try a different one
thanks ax
  #62
Old 10-27-2013, 03:18 PM
AXracer's Avatar
AXracer
AXracer is offline
Return the steering box?
  #63
Old 10-27-2013, 03:33 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
no the pump ,,i guess you can get bad ones ??
  #64
Old 10-27-2013, 05:06 PM
AXracer's Avatar
AXracer
AXracer is offline
The pump is hissing?
  #65
Old 10-27-2013, 07:04 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
yea hissing or wining i guess seems it does it more after it gets hot , i drove it home tonight after it sets for 2 hours and i couldn't hear until i got almost home then i heard it ,, got me i will try to get closer to see where it is coming from
thanks ax
  #66
Old 10-27-2013, 11:57 PM
AXracer's Avatar
AXracer
AXracer is offline
Make sure the belt isn't too loose or too tight. Look to see if it's getting shiny (too loose). Too tight and you'll rip the bearing out of the pump. Usually if the belt is too loose it will squeal when turned to extreme when pump is pushing max pressure.
  #67
Old 10-28-2013, 05:15 AM
lilrobo's Avatar
lilrobo
lilrobo is offline
Thanks ax
Ill give it a day or so to see what happens, i say i might try a new pump,, myluck i got a bad one lol i really could use one with the low pressure port facing the other direction
Thanks i do like theway it drives, , no more slack at all and no more catching, i had a catch at 1 spot, ,, much better
  #68
Old 10-29-2013, 05:41 PM
lilrobo's Avatar
lilrobo
lilrobo is offline
well the new pump seem to fix the wining ,, now on to nest thing ,, i want to lower the rear ,,i need to do something with spacers that go from chevy to ford wheels ,, i am looking for chevy wheels that match now thats going to be hard lol
thanks guys and ax for all that you do here
Dude-Ford
44
01-20-2017 06:53 AM
rbsample
02-21-2012 11:15 PM
58 ford
17
06-17-2009 05:09 PM
trintek
06-29-2007 11:30 AM
G Guess
10-14-2006 11:22 PM
Quick Reply: its begun
