my 1988 f250 does not want to start. hot or cold. but will
when i pull start it . it is the easiest truck to pull start . the second i let out the clutch in 2nd it fires. i am going through starters all the time. and now it is dieing after i get going down the road. my 87 f250- did this and my tank fuel filters in both tanks got into the fuel line. and the shop charged me $900 to fix it. i don't have the money to get the .done again. how do i clear the lines myself ?
Hi irishgot8 Welcome to FTE Sorry to hear about your issues with you F250. This forum is more for new members to introduce themselves to the community. There are a lot of very knowledgeable bunch of folks here who are always willing to help a fellow Ford owners that has a problem or a question with some advice.
I would try posting your question in here : 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
and see if some of the clever souls amongst us can help answer your question.
Received 3,102 Likes
on
My 1988 f250 7.3 diesel . I fixed my starting problem. But
Now I move on to a odd one. First my rear tank full of fuel would let the truck die. Like it was out of fuel. Now the front tank is doing the same thing. I can start the truck up and drive a mile or to , then it starts chugging. I can switch tanks back and forth for a few miles but it will eventually die. after an hr. I can do it all over again. Now note the rear tank went bad 6 months be for the front tank started acting bad. Could the tank switch cause this problem ? or would it be in the tanks . I don't see how it could be any thing after the tank switch. because the front tank did not give me any trouble for at least 6-8 months after the rear tank went bad. And i am down to less than a $100. I've spent a grip under the hood this week did the fuel kit on top new g plugs, starter, starter relay, G.P. controller, G.P. relay. bla. bla. bla. I am broke. If you or some one you think could help please let me know. Thank you very much for you time, Joe
My Starting Problem Is Solved
The wire that powers the glow plug controller had a brake in it . Put a new wire in and DONE. And my fuel problem solved. It turned out to be a combination of problems , two main problem. First was tank filter screen . The second was lift pump. It probably went bad because of the screens in the tanks. The pump I bought at O'Riellys has gone bad , replaced it and have a strange new problem That I just Posted. I want to thank everyone for your help. It was very help full and very much appreciated ! Thank you for the time you took to help some one you do not even know. This is a very cool site. Thank you, Joe O'Leary
lightning.fast.svt
05-19-2015 06:35 AM
