Good Alu Head Castings To Look For? - Ford Truck Enthusiasts Forums
Old 10-19-2013, 08:51 AM
Bamadawg63 Bamadawg63 is offline
Bamadawg63 is starting off with a positive reputation.
I am ready to pep up my '78 F100 w/factory rebuilt 302. I also have a '69 351W block in the wings to be rebuilt. I already have a Lunati retro hyd roller kit, cam and Holley 4bbl/600ish in the closet that I bought for the 302.
I was wondering what some good aluminum castings, new/used, that I should look at to do a head swap and leave the factory stroke/pistons on the 302 but also to use later when I get the 351W block ready to drop in. I did not rebuild the 302, but I would bet the owner, who was a mechanic, put the stock type with a valve relief back in it. Not sure how small I should go with the quench size... 58cc-64cc in using the stock type pistons using pump gas.
Any suggestions accepted and thanks!
Old 10-19-2013, 10:41 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Everything from the basic Edelbrock Performer to Dart Pro1, to AFR and TFS aluminum heads are healthy upgrades over any of the stock Ford heads, I'd suggest you look for something with 1.90/1.60 valves and 60-62cc chambers which will be small enough to provide decent performance on the 302 but not so small it would make static CR too high on the 351.
Old 10-20-2013, 02:02 AM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
I would go smaller on chamber size to maximize the ratio on the 302. You can always choose pistons for the 351 to match the smaller chambers. 58 cc's are the norm for the smaller chambers, choosing from 60-62 isn't going to change that much anyway on a 351, it will though limit your choices in heads, possibly forcing you to skip an otherwise good deal. I bought Canfields when I went shopping ten years ago, was about to buy Brodix then, till the Canfield deal popped up. Never regetted the choice I made.
Old 10-20-2013, 02:11 AM
Been seriously looking at the Trickflow Twisted Wedge 170 today... nice head. Seems also Ford Racing goes a long way by CNCing the intake and exhaust runners for a nice price... 5-angle valve job also.
Old 10-20-2013, 02:42 AM
Buy what you can afford. About the only heads I'd steer clear of are those cheap Chinese heads sold on Ebay (Procomps ?) Or any used head run on a drag car.
Old 10-20-2013, 03:09 AM
I wanna invest about a grand on a complete set... jus gotta make sure they achieve what I need... don;t need any full on race bored strip heads.
I like the idea that Trickflow did with the valves on the Twisted heads... kinda like the Cleveland heads.
Old 10-20-2013, 09:59 AM
Conanski's Avatar
Just be aware the Trickflow heads require matching pistons because of the offset valve locations.
Old 10-20-2013, 12:00 PM
They claim the Twisted Wedge 170's do not require cut valves for lifts up to .550". My Lunati cam is spec'd @ .445"/.477" - so I should be golden.
I read through their install sheet... they want us to go through the whole clay molded combustion chamber with heads bolted down... so I gonna make sure I follow their install and check clearances.
Thanks for the heads up tho Paul!
Old 10-20-2013, 12:05 PM
They do require special special length hardened push rods.
Old 10-23-2013, 12:31 AM
slashfan7964's Avatar
slashfan7964 slashfan7964 is offline
slashfan7964 is gaining momentum as a positive member of FTE.slashfan7964 is gaining momentum as a positive member of FTE.
I've head good things about AFR 165 heads.
Old 10-23-2013, 05:44 AM
Cobra-Kai's Avatar
Cobra-Kai Cobra-Kai is offline
Cobra-Kai is starting off with a positive reputation.
I've layed eyes on this heads:
http://www.summitracing.com/int/part...x307/overview/
What does others think?
Is it a good choice?
Old 10-23-2013, 09:46 AM
I wouldn't hesitate to use FRP products... they been in the racing business fer a long time. I would almost bet they design the heads and molds and have them poured at a foundry that does alu OEM blocks/heads... not sure if they actually own a alu foundry or not. We have a alu foundry in our lil town... used to be called Teksid, once a Division of FIAT. They were sold to Nemak... they do alu blocks/heads/intakes for several auto companies.
Old 10-23-2013, 09:56 AM
Conanski's Avatar
These are pretty good heads and they compare favorably with the TFS170s in terms of airflow.. 240/170cfm vs 250/170cfm.
Old 10-23-2013, 05:58 PM
jimbbski jimbbski is offline
jimbbski is starting off with a positive reputation.
I put on GT40-X heads on a 5.0L with good results. There were the X & Y version with the X version offering more performance which is what I used. Both were offered in 65 & 58 CC versions. I'm not sure how easy it would be to find a set but these heads bolt right up, use stock valve train parts, etc. Add a set of 1.7 RR with your cam while you're at it.
These heads were cast with a different combustion chamber shape then the iron GT40 heads for more turbulence and better combustion. For use on a truck and a mild cam these heads should work well.
Old 10-23-2013, 07:48 PM
Yea... there was the Early SVO Ford Motorsports GT40X heads... then later Ford Racing GT-40X Turbo-Swirl. Not sure the casting/spec differences of the 2 versions.
Nate
Piston Choices for Std Stroke 351W Bamadawg63 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 12-04-2013 09:43 PM
GT40 casting ID - Cobra heads on an Explorer? Lagniappe Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 10-28-2013 04:59 AM
351w 289heads cam selection caste5ae Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 20 11-11-2012 10:27 AM
351 EFI build questions f100beatertruck 1978 - 1996 Big Bronco 7 04-17-2010 02:02 PM
Piston orientation 351w dbc Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 05-14-2003 06:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
