What to look for? - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
What to look for?
Old 10-19-2013, 05:06 AM
jeff gammon's Avatar
jeff gammon jeff gammon is offline
jeff gammon is starting off with a positive reputation.
What to look for?
I have spent hours looking through this forum, but I havnt found a thread on what to look for when buying a unibody. Im not saying there isn't one here, I just havnt been able to find it. I have never looked at one up close and personal. Now I have the bug to own one. Im not concerned with drive train. I have owned antiques before and right now have a 67 galaxy. Just please tell me what I need to look out for when it comes to body. I have seen some talk about torque box, cab mounts and rust in floor pans and the area just below the bottom door hinge. I live in northeast Arkansas and just don't see to many of these around here.
Thanks,
Jeff
Old 10-19-2013, 12:42 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
The areas you mention are of primary concern.
The torque box is a sheet metal stamping at the rear of the cab under the bed floor that ties and stiffens the center of the truck to prevent flexing. This is extremely difficult to fix as it is a body off frame fix. The rear cab skin, cab floor and this box all tie together in a multi layer unit.
Cab mounts can be fixed. not super critical.
The model 66 lower hinge pocket and cowl are the same stampings as a standard Model 81 cab. Lots of rust in these area again requires extensive rebuilding of the multiple layers. The outer pillar skin is available aftermarket.
I only buy unis as parts trucks if the torque box is shot.
Also make sure it has the correct doors. no dog leg on uni doors.
Garbz
Old 10-19-2013, 11:16 PM
Garbz
Could some one post a pic of the troque box?
Old 10-20-2013, 03:47 PM
garbz2's Avatar
Upper shot of a short bed. This has the bed floor removed
Underside shot of a pristine short bed
Garbz
Old 10-20-2013, 09:27 PM
okiewelder okiewelder is offline
okiewelder is starting off with a positive reputation.
Garbz, you are a welth of information. I have been working on my truck for so long l am replacing the patches l laped 20 years ago instead of butt welding.
Anyway do you have a closeup picture of how the top of the touque box is supposed to look with the floor removed? I have some of my floor removed and there is some rusted out so l have no idea what its supposed to look like.
Thanks
Old 10-21-2013, 01:31 AM
garbz2's Avatar
I will see what i can dig up.
Garbz
Old 10-31-2013, 11:17 PM
nabengt nabengt is offline
nabengt is starting off with a positive reputation.
Garbz
Looking at a 61 unibody and just found out about this torque box issue. This truck has matching patches on the bed side. Sign of trouble?
Old 11-01-2013, 11:16 PM
[IMG][/IMG]
Old 11-01-2013, 11:18 PM
Just figured out the pic upload thing. Check out the patch on the bedside. Evidence of some torque box issue?
[IMG][/IMG]
Old 11-01-2013, 11:25 PM
garbz2's Avatar
Yes a sure sign of trouble.
Her is another shot of a short bed. the front shows how it goes up to meet the rear floor and bed stampings.
Here is why unis rust out so easy. If the truck was not undercoated new it only has primer on the underside. No paint. Primer is porous and will suck up moisture. Plus the bed would quickly pinhole from the underside at the box. There was nothing in there but raw metal.
Instep rust came for the inside out through a flaw in the undercoating.
Garbz
Old 11-01-2013, 11:36 PM
Did that pic show up for you?
Old 11-03-2013, 08:54 PM
garbz2's Avatar
Yes, By the patch it looks like some work was don in the box area.
Old 11-03-2013, 09:08 PM
Bummer. It's a cool truck. 292 with BW 3 spd overdrive
What to look for in a used 6.7 TheLandYacht 1999 to 2016 Super Duty 13 01-05-2016 04:41 PM
In the market for a new hood! caedo 1999 to 2016 Super Duty 5 08-15-2014 12:21 PM
Glow Plug Boot, Home Made dfsmitty60 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-02-2013 11:09 PM
Odometer rollback issue 93sc 1987 - 1996 F150 & Larger F-Series Trucks 5 08-21-2013 09:52 AM
Ignition Module Jeff L. Davidson 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-10-2012 04:32 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
