96 5.0 header change
already have shortys but debating switching to long tubes, is the difference noticeable? any input/reviews on these? http://www.summitracing.com/search/y...rder=Ascending I will post pics of my current exhaust tomorrow!!
shortys to long tubes will put a grin on your face, but it wont be from power. it makes the pedal feel much more crisp and responsive, which will also lead to better fuel economy. no single thing you do to that 302 will work miracles, but long tubes will be the single most effective mod you could do to any of these trucks.
do yourself a favor and get pacesetter. theyre well worth the extra price over the other header names. also, consider doing your engine mounts while youre in there. engine mounts are a crucial element in header clearance and fitment, as well as y-pipe fit. the y pipe will be tight, you don't want sagging motor mounts in the fitment equation.
shortys are pointless, unless theyre installed as an alternative to a cracked or ruined manifold (theyre almost the same price new)
right now I've got the pacesetter shortys from summit and they fit very well. But summit only offers hedman long tubes for my 96. this is my exhaust set up now.
this is the view of both headers but mainly the passenger side, you can see the starter.
http://i1294.photobucket.com/albums/...psc0cfcb72.jpg
this is the drivers side
http://i1294.photobucket.com/albums/...psf94f3c97.jpg
I have duals until this y pipe which is underneath where my bench seat would be. then it goes into the si/so dynomax bullet
http://i1294.photobucket.com/albums/...psaaae3c94.jpg
why must the entire exhaust be re done? I mean I made the y pipe that's on it now, just custom mandrel bends. So I planned on just cutting it up then keeping the rest of the pipe but just sliding the straight portion. Can you understand the set up from the pics?. What did you notice from the long tubes, performance and sound wise.
Performance it helped some. My biggest help was exhaust..
But my 5.0 in no way is stock
I know the stock exhaust is kind of a killer on the 5.0's especially. From what I've learned exhaust and gearing wakes them up quite well. I'll try to explain my set up a little better.
The y pipe is long, I don't have a cat. The pipe from the left header comes down past the oil pan then shoots across the cab to just inside the frame, the right header pipe just drops down and goes straight back. The two don't meet up and go into 1 pipe until its even with the exterior door handle. It then goes into a Dynomax Bullet (which is from what I was told a glorified glasspack) then it exits right by the start of the bed, before the right rear tire. The y pipe is 2 1/2 inch pipe then once it meets it is 3 inch
