Truck bouncing in rear
Next would be a lost driveshaft balance weight.
However, Ford has a couple TSB's concerning driveline vibration in the long wheelbase trucks and also the short wheelbase trucks.
For example my Supercab, Shortbed required taking the tapered rear blocks and swapping them side to side to cure the vibration at 50 mph.
The longbed guys usually just shim there carrier bearing down to cure there's.
https://www.ford-trucks.com/forums/1...with-pics.html
I've seen 1/2", 5/8" and even 3/4" spacers/ washers used.
Josh
Josh
Carrier Bearing is more then likely the problem at those speeds
This more for those searching bouncing and the above doesnt fit:
I have an early '04 350 4x CC LB its rough everywhere, like Heavy Assault said trade off for what the truck will do. There are two 10 mile sections of HWY where I live that when I am cruising @ 70mph I'm bouncing very harsh. I switch lanes and its good, or go up to 75mph and its tolerable. My dad told me every Ford truck he has owned (4 different yrs and models) did that in those areas, its just the "harmonics" (for lack of better word) of the bumps vs the wheel base. New shocks front and rear adjusted to max firmness helped a lot too.
Edited for readability
The long bed bounce is an inherant issue at certain speeds in the 03 thru 07's. Ford changed the rear leaf position and length in 08 to correct this. My 05 does it, only on certain stretches of highway, between 65 and 75 mph. When I have a load in it, it is not an issue. Just when empty. Put the wife in the bed instead of the cab. No more bounce and you can hear the stereo.
