PA DOT Q and A - Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: liftnw8z
PA DOT Q and A
Old 10-18-2013, 07:58 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
PA DOT Q and A
http://www.ford-trucks.com/forums/12...t-q-and-a.html
This is a thread I started in the S>D section and others thought I shoukld put it here.
Old 10-23-2013, 01:27 AM
Oldtrucknut7077 Oldtrucknut7077 is offline
Oldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputation
Thanks for the heads up!
Old 11-04-2013, 09:44 PM
Ferguson65's Avatar
Ferguson65 Ferguson65 is offline
Ferguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant futureFerguson65 has a brilliant future
Figured I'd bump this back to the top. I got a little Monday morning surprise from DOT today in my work truck on 113 outside Phoenixville. Full inspection, 0 citations.
Looking forward to making this to know how to get through just as clean with my pickup. It's not really a matter of IF, its a matter of WHEN DOT will find you, at least here in PA anyway. Extra knowledge goes a long way.
Old 11-05-2013, 08:21 PM
Yep, I was North bound on 611 between 113 and 412 basically right across from Wehrungs Lumber Yard and DOT was pulling over all trucks going south. You just never know when they will pop up.
If anyone can't make it to the Q and A post your question here and I will ask it for you.
There is a few I want to ask and I will post them as the date gets closer.
Old 11-07-2013, 06:05 PM
Here are 2 questions that come to mind:
I have a truck with a GVWR of 14,000lbs., do I need a medical card?
How are trucks supposed to be registered as regards to weight, does the weight class sticker cover the truck only or is it supposed to cover truck and trailer?
Old 11-07-2013, 07:03 PM
Ferguson65's Avatar
Expanding on that......
If the trailer is only used for personal use, NOT business.
Some of mine. I'm going to write down a list.
When, exactly is a class A license required, and is it required if the trailer is an RV (over 10,001)
Where can you apply for a Non commercial class A and take the test without a total runaround from the state?
Old 11-17-2013, 10:44 PM
Well I find that I need a medical card, fire extinguisher and flares. I have to renew my license once a year. I don't need a CDL but I might as well have one.
I didn't get to ask about my weight class sticker because I had to leave around 11 to go to Jersey so I guess I will have to make some phone calls.
Old 11-22-2013, 01:06 PM
Scoop531 Scoop531 is offline
Scoop531 is gaining momentum as a positive member of FTE.
I just had the DOT at my shop as i just finally applied for DOT Number after 25 Years in business. We mainly work In PA being so close to De NJ and MD we do travel into those states its amazing you are fine to drive up to 26,000 lb trucks here in PA without a DOT number medical card etc etc But once you cross a state line your in the wrong and that number drops to 10,000 lbs or over. We kept getting hit with about $300 DOLLAR FINES so it was time esspecialy since i have gone from 1 15,000 GVW truck to now 3 26,000 GVW trucks in the last year they deff see us coming. and its not for trucking service or long hauls these are all local trips under 50 miles for my construction business. But now I have to fill out all types of logs and keep better records etc etc and have random drug screenings. hey im sure its saving a life just also gotta be a hassle
Old 11-22-2013, 05:00 PM
And now that this new Bill has passed, fines will be doubled, registration fees are going up and of course gas prices. I can feel the money being sucked out of my wallet. So being legal will be cheaper, it might be a hassle to get the paper work started but once it's done I will feel better about being prepared next time I get pulled over.
Ring orientation Rasputin53 1967 - 1972 F-100 & Larger F-Series Trucks 7 12-16-2015 04:37 PM
Dot 4 brake fluid senix Crossovers 7 10-24-2014 03:41 PM
Tired of trying to figure out the DOT rags 2kmelat 6.7L Power Stroke Diesel 15 05-21-2014 08:25 AM
Mixed DOT 3 and DOT 4 fluid accidentally-Problem? Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 02-17-2014 11:10 PM
Help brake fluid capelo 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-08-2014 05:30 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
