Ford Escape 2005 and change of seal for rear differential - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 10-18-2013, 02:52 PM
-Tapsa- -Tapsa- is offline
-Tapsa- is starting off with a positive reputation.
Hello
If somebody have experience for changing of rear differential seals, I like to hear about possible challenges or difficulties - thanks in advance.
If you open following link, you can see part number 1177/Ford number 4656029.
Ford Original Catalog : Maverick 2000-2006 (TM1) :
Tapio
Old 10-19-2013, 03:16 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
If your doing the one where the drive shaft goes I mark the nut position with the flange before removing the nut to put it back on to the factory set torque.I have not done a Escape but its worked on others I have done.You could scribe a line or use a centerpunch on the 2 items.
Old 10-19-2013, 05:11 PM
... a good idea. As I remember my earlier repairs, it's not one or two times when I am wondering about refitting - thanks about this tip
Old 10-21-2013, 07:47 AM
Dan Robertson Dan Robertson is offline
Dan Robertson is starting off with a positive reputation.
"The book" gives directions to remove the entire lower trailing arm but I found it easier to leave it hanging. I have replaced both rear wheel bearings and then later, the left axle seal in my 05 this past summer. The first one took several hours longer but after that, I found the short cuts. I loosened up all of the bolts and unhooked the tie rod ends, unbolted the lower end of the rear shocks and took the coil spring right out from under the vehicle. I let the brake plate hang from the park brake cable and wired the caliper up out of the way. I marked all the bolts that adjust the alignment before I loosened any of them so that I could put them back to the proper specs. If you position things just right, the axle shaft will come out but its a tight fit. I had to improvise a puller to get the wheel bearings out with the housing still on the vehicle. We ended up using a wheel bearing puller with adapters from a ball joint press. I also found out that the front seal where the drive shaft goes into the differential is available at the local auto parts store but the left and right axle seals are a dealer only item. If you ever need to replace the center support bearing in the drive shaft, it is now available aftermarket. (I found one on line at a company called Dorman Products) The dealer wanted to sell the entire drive shaft.
Old 10-21-2013, 08:12 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
You say caliper on the rear? The 2005 had disc brakes all the way around? I wonder what year they went to drums?
Old 10-21-2013, 10:41 AM
Hi and thanks about reply and a good tip's - I let you know how it goes.
By the way, have you keep old axle seals and if yes, what are dimensions of those?
I have ordered new ones but it's good to know that they fit on place, this reason why I am asking possible dimension of old one.
Tapio
Old 10-21-2013, 06:12 PM
I didn't bother to save the old seal. I have no idea when Ford put drum brakes on the rear but my 05 doesn't have them.
Old 10-21-2013, 06:46 PM
Quote:
The 2009 has drums.
Old 11-01-2013, 05:53 PM
I replaced seal in right side. I made the job according Haynes Repair Manual but without any special puller or similar tools. Thank you guys about help and comments
Old 11-01-2013, 09:01 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
Originally Posted by wptski View Post
The 2009 has drums.
My 07 Mariner has 4-wheel disks....
Old 11-01-2013, 09:53 PM
Quote:
Is it a 4WD?
Old 11-02-2013, 08:59 AM
Is it a 4WD?
Well, it's AWD. Did they put the drums on the 2WD versions and disks on the AWD ones?
Old 11-02-2013, 10:02 AM
The AWD term is a buzz word, it's a fixed ratio, non-transfer case 4WD.
I "think" or thought that the FWD has disks on all four corners. My '09 4WD has drums in the rear.
Old 11-02-2013, 07:33 PM
bmuhlbach's Avatar
MY 01 awd is drums on rear.My Moms 05 fwd. has drums aswell
94.5-97 7.3 manuals, parts lists, diag and more knottyrope 1994.5 - 1997 7.3L Power Stroke Diesel 12 11-21-2016 11:51 PM
Strange axle code number... jplinville 1987 - 1996 F150 & Larger F-Series Trucks 2 09-01-2016 06:17 PM
front seal or inner axle bearings? 88_F0RD 1987 - 1996 F150 & Larger F-Series Trucks 11 08-27-2016 03:22 PM
front differential seal 1988 ford 150 88_F0RD 2011 & Newer Explorer 4 08-26-2016 06:17 PM
Ford Part Number for Pinion Seal and Rear Axle Seals Whitey Ford 1999 - 2003 7.3L Power Stroke Diesel 15 03-01-2012 04:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
