holley 1904 problems - Ford Truck Enthusiasts Forums
Old 10-18-2013, 01:05 PM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
the fuel inlet stripped on the body of carb...does anyone know if it is possible to drill and tap? does anyone have a spare body around for sale?
thanks
Old 10-18-2013, 03:25 PM
Damifiknow's Avatar
Damifiknow Damifiknow is online now
Damifiknow is starting off with a positive reputation.
Whole new one at advance auto online is $150. I've seems em on for as low as 10 bucks on eaby that need rebuilding. I would re-tap the treads same size to clean em up and use pipe thread tape. I think its only like 7psi from the pump so not much pressure you are holding back.
Old 10-18-2013, 04:39 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
You might also want to use some two part epoxy as a sealant when you try to thread it back in after cleaning.
Old 10-18-2013, 05:09 PM
Maltman's Avatar
thank you gentlemen...the threads are stripped half way in. a fellow FTE member gave me a great deal on a spare of his. My carb has a new rebuild kit so between the 2 of them I will be back in business!
Old 10-18-2013, 05:13 PM
Damifiknow's Avatar
Quote:
Great idea. I've drilled and tapped JB Weld
Old 10-18-2013, 05:56 PM
oldebrush's Avatar
oldebrush oldebrush is offline
oldebrush is starting off with a positive reputation.
I am not sure how well the Teflon sealant tape works with gasoline, especially having ethanol in it. I do know there IS a sealant tape available for fuel fitting sealing. I just don't know off hand where to get it. Napa, or such may be a start.
Hope this helps.
Aloha, Tony
Old 10-19-2013, 07:54 AM
twitbeck twitbeck is offline
twitbeck is starting off with a positive reputation.
teflon tape alternative
I found this on another forum:
This is the stuff you want. Should be available at any autoparts store:
http://www.permatex.com/images/Displ...otos/56521.jpg
I have used it, and it works on fuel fittings. Permatex 56521 high performance thread sealant.
http://www.permatex.com/products/Aut...ad_Sealant.htm
Old 10-30-2013, 03:36 PM
Maltman's Avatar
I received a used carb from fellow member last Friday. I used the main body of his and everything else from my carb since I had just rebuilt a few months ago. Seems that the fuel inlet threads are very specific for Holley on these 1904's and the PO put new fitting and threads were just barely off and ended up stripping my carb over time.
2 questions
1-truck now likes to be COMPLETELY warmed up or will sputter and bog if try to drive too soon-really gotta feather her...once warm she runs like a dream. Is this something an adjustment can overcome?
2-how do you give rep points to another member?
BODY MOUNTS BAJI26 Excursion - King of SUVs 8 06-16-2015 08:17 AM
2008 Escape question RangerDJB Escape & Escape Hybrid 1 01-23-2015 10:02 PM
plastic bushing on throttle body What was I thinking 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-19-2014 07:27 AM
79 body color grille? harrisford 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-29-2013 06:48 PM
body lift on diesel....why not? jonjayjabroni Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 12-18-2004 12:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
