I cleaned my throttle body last weekend. Man there was more carbon there than on the bottom of a burnt bisquit! I have 76K on my Ranger. The person that had it before me took great care of the outside but not the enginge. I am sure they never cleaned it. I used CRC and they recommend you clean it every 3000 miles! Now I don't know about that often but afterseeing what was in there I promise to clean it often. By the way, it didn't help the ping any. However, there is a noticable improvment in throttle response.
__________________
98 Ranger 3.0L
Spray in liner
UWS Bed Protectors
Dee Zee tailgate cap
Curt class III hitch
Same thought I had when I first cleaned the TB on my Ranger 4.0L ....I wisheded I had done it sooner and more often! I also experienced better throttle response and promised myself that I would clean it as a part of my regular maintenance plan from that day forward. So when I recently purchased a used '97 Taurus (vulcan) one of the very first things I did was clean the TB. I believe in it.
Easy project. To get at the throttle body to clean it, you just have to remove the air cleaner outlet tube that runs between the TB and the air cleaner box.
This thread has some more info on how to do it: Throttle Body
Thanks Rock! I'll pick up some TB/Air intake cleaner today and give it a try. My pickup has about 55,000 miles on it and it has never been done so it can probably use it. However, I don't have access to compressed air right now. Do you think that will be a problem to just use the cleaner and not the compressed air?
PS I will also change the oil in the near future after performing this task.
You don't have to use compressed air to clean the TB, but I think it helps out a lot.
FYI .....many auto parts stores carry small portable cans of compressed air that you can get right off the shelf. And if you can't find one there, try computer/electronic stores which also sell them.
Just a quick thought...cleaning the throttle body is easy. I don't understand why manuals don't recommend doing it in the maintenance chapter? Perhaps a liability issue or perhaps most people are too lazy? Seems like a common sense thing to do to me.
Originally posted by jcandrew Just a quick thought...cleaning the throttle body is easy. I don't understand why manuals don't recommend doing it in the maintenance chapter? Perhaps a liability issue or perhaps most people are too lazy? Seems like a common sense thing to do to me.
Interestingly, there are some other shop maintenance/repair procedures that Ford seems to try and keep under wraps - cleaning the MAF sensor comes to mind- and they are also notably absent from repair manuals. Yet cleaning the MAF has helped countless people experiencing a variety of driveability problems. So, I guess the point is that you're not going to find everything that can benefit your motor in a published manual.
Quote:
Originally posted by MickeyP
...or perhaps the benefits are negligible. Why isn't that a possibility?
My guess is that Ford feels the same way, and also doesn't like the idea of the "average Joe" tinkering around with the TB.
Negligible benefits to claning the throttle body????? I can tell you it is very beneficial. There are several reeasons why Ford would not suggest it. One is the liability aspect. Some moron sprays half a bottle of TB cleaner in the intake and washes all the oil off cylinder walls then sues Ford. Any major company also has to take care of its dealers and garages. If Ford wanted to they could make vehicles that had virtually no maintenance. BUt why would they? The majority of car owners are not going to home repair things anyway. And then all those high priced income making entended warranties would be garbage. Ford makes great vehicles but it is still a profit oriented company. And that is the bottom line.
__________________
98 Ranger 3.0L
Spray in liner
UWS Bed Protectors
My mechanic said that he cleaned the throttle body of my '00 XLT because I was complaining of a rough idle.
It clearly states on the throttle body:
CAUTION: The throttle body bore and plate area have a special coating and must not be cleaned.
If he did actually clean it -- what damage/problems could this cause?
He also cracked a spark plug and didn't test drive it. So I picked it up and it ran like crap and set off a CEL. He put in a new plug and cleared the CEL by disconnecting the battery. The truck seems to have relearned but now I have a definate miss under hard acceleration. The miss isn't consistant but it is there. It feels like my old Sentra did when I would turn on the A/C while driving -- a momentary loss of power that recovers right away.
Any help/suggestions would be greatly appreciated!!!
To be completely honest, I would not have a lot of confidence that your spark plugs are installed properly. Using the right type of plug for your type of motor is vital. Gapping and torquing the plugs to proper specs is just as important. Maybe your mechanic was in a hurry or something, I don't know, but breaking a plug makes me wonder about the whole installation process.
The right spark plug wires, properly installed, are also very important. And a new air filter should be part of any tuneup.
You also might want to think about dumping a bottle of fuel injection cleaner (Chevron Techron gets good reviews around here) into your gas tank.
If it were my truck, that's how I would appropach the problem at first.
I ran a bottle of Chevron cleaner through and I still have the rough idle. I bought a set of plugs (Motorcraft) and wires and I'm changing them this weekend (I have read good and bad about the OEM replacement plugs esp. with the AGSF22PP number but I thought i'd go with OEM first).
I'm also changing the air filter and was think about cleaning the MAF sensor.
A lot of posts that I read say that a rough idle is just part of having a 3.0 and that a lot of them do. Doesn't seem right to me though.
