53/55 f 100 windshield size?
Ok ..I building a 33ford fiberglass streetrod that is 10" wider then stock..a 53/55 windshield looks like something I could use after cutting it down. Could some one PLEASE tell me how wide it is at the top, bottom and how tall it is..I'm needing something like 44" wide at the top, 45" at the bottom and 18" tall..I'm sure it is to wide but someone has to keep the glass boys happy..thank you Keith
The windshield on a 33/34 Ford is flat...the f100s are not. That said, the measurements from the center of the curve/radius in each corner is 53-5/8 across the bottom and 50 inches across the top. The diagonals are 54-1/8. There is about a 5-3/4 inch bow in the windshield across the lower edge. The height of the glass in the center, top-to-bottom, is 17-7/8. I took my measurements from the cab itself but the glass fits into this opening fairly closely...if you intend to use the same rubber seal as the F100 then these are the dimensions you'll need.
f 100 windshield
I want to thank both you guys for dropping me a line..The first 33 ford I built I used a mini cooper (old style windshield) curved windshield It was just alittle low,,,so this time around looking to be aliitle taller 17 7/8 is just right my curve is 4" at 45" wide so..a 5" curve at the bottom will be pretty darn good once it is cut down to the 45" width .. the mini was to narrow at 42" on the top ..so I can cut the f100 to the correct top width ..
BJmayberry IF you don't mind could you send your measurement (being that the windshield is out) you GUYS have made my day...
Now does any one have an OLD windshield forsale ..for a pattern? If so let me know...THANK you again..Keith
F100 windshield
If you wouldn't mind (When you have the time)..I'd love to get your measurements on a windshield that is out ..BUT it sure looks like something I'd be able to cut down with out to much trouble I need 44" across the top 45" on the bottom and 17 1/2 to 18 in height. if you could could you tell me the curve at 44-45" I have about a 4" curve..but the other guy said about 5 1/2 at 53" wide so I should be pretty close. I wrote a reply in my thread..about the windshield that I'm using now..THANK you so much..I've been looking for something I could use for a long time most I'd have to cut both the width AND the height.. thanks again Keith
windshield
Thanks for sending those pictures..I REALLY think that it'll work I've been looking for about a year to find a windshield that I could use..I knew that it would be to wide but the height is just right and the curve looks very close enought to make it work...you guys have really came though ..thanks again Keith
MR BJMAYBERRY2 about the windshield
Keith DeArmond
6160 ne 72nd place
Silver Springs Fl.34488
thank you
I guess no one wanted to take the time or cared..but I did ask around at the swap meets and even on craigslist Funny I had thought the same thing drawing on paper towels..but if the curve is anywhere near close to what I need I'm planning to order a new one (any idea who has the best price) I had been looking for over a year on every thing that came down the road, one day while looking on e-bay at windshields the f100 came up (who would have thought they still made windshields for them?) not me and I'm an old car/truck nut (flat glass yes but curved glass..no ) I've been 4 years in the building of this car and the main problem was the glass was to low, now hopefully the next one will be more driveable (I do have the molds to produce more bodies. I'll keep you posted ..thank you so much .Keith
Forgot today was a holiday. No mail Hopefully they'll get it tomorrow. Are you cutting the glass yourself? I can't even get one out without cracking it, can't imagine cutting one down. I'd ask around at local glass shops if they can get one. EBay has them pretty reasonable but the shipping is almost as much as the glass
not cutting the glass
one of the main reasons I'm so happy is the curve looks pretty good BUT the height is GREAT so the glass guys only need to cut some off the sides, they didn't seen to think it would be a problem..big swap meet coming up in nov. I've heard there might be some new glass there..thanks Keith
