2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
'12 Expy EL Rear diff leak
Old 10-17-2013, 11:04 PM
2.5gl's Avatar
2.5gl
2.5gl is offline
So, not that old of a rig, 18 mo old and just over 20,000 miles. Problem is, we have had the rear differential seal replaced 4 times now (Left side). 1st seal around 9K miles, 2nd around 9800, 3rd at 19,900, 4th done today at 20,800. This is a large dealer, running day and swing shifts in their service center. All repairs to date have been done under the same "team's" care. I do not know if that means the same technician too, I had not bothered to look that up.
We do tow a travel trailer about 1-2 times a month, typically around 200 miles round trip over "flat" terrain some weekends, or mountains the others. We generally stay at or just above the speed limit towing the trailer loaded between 6500-7500 lbs. Trailer sway control and weight distribution is used putting between 400-500 lbs to the front of the truck. It handles it well, far better than our 2006 expy used to.
Anyone had repeated issues of seal failure in the rear diff? I'd like to know how often they fail, if you are towing/hauling, how many miles a year? I am trying to get an idea of whether or not this truck should be used for this much towing. Really wanted an Excursion, but this is the wife's rig. Now I get to deal with the potential inadequacies...
Thanks!
Lewis
Old 10-18-2013, 05:37 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
They are treating the symptom not the root cause. Something is making the seals fail, if it happened once you could say bad seal or bad assembly, but not repeated times. You use isn't unusual.
Old 10-18-2013, 08:34 AM
2.5gl's Avatar
2.5gl
2.5gl is offline
I checked it again last night.... Cleaned it up so that the diff is dry. Wife went to the store, there is another drip of gear oil hanging out on the bottom of diff. They said they cleaned it up. Either they didn't, did a really bad job, or the stupid thing leaks like a sieve. Even though this $h1t is under warranty, I feel like I should just do it myself to know it is done right and eliminate the variable of others incompetency. How difficult is it to get Ford to step up and put in a whole new differential?.
Old 10-18-2013, 08:43 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Did they check the vent tube? I wonder if the axle shaft has nick in it or something allowing it to leak even with the new seal.
Old 10-25-2013, 06:53 PM
bunky383's Avatar
bunky383
bunky383 is offline
Yep, make sure that the vent breather isn't plugged. get the dealer, or yourself if you have an air compressor, to put some compressed air in through the filler plug and make sure that the pressure bleeds off on top where the breather is. If that is plugged, when you drive and the fluid heats up and expands, it will force its way out, either the output shaft seals or the pinion seal. if it is plugged, gear oil will spit out of the fill plug when you remove the blow gun
jwchenault
1997 - 2003 F150
05-30-2015 11:15 PM
jimw411
1983 - 2012 Ranger & B-Series
07-13-2005 10:27 PM
g tinsley
09-13-2004 05:57 AM
jowilker
06-23-2004 05:38 AM
50jd60
11-19-2003 10:24 AM
Quick Reply: '12 Expy EL Rear diff leak
