Carb trouble 81 4.9L - Ford Truck Enthusiasts Forums
Old 10-17-2013, 10:07 PM
mshefty mshefty is offline
mshefty is starting off with a positive reputation.
I have recently acquired an '81 F-150 with a 4.9L inline with a one barrel on it. It has some vacuum leaks I am tracking down as well as some other issues. My main issue right now is that sometimes my truck will start just fine and drive for about 7-8 miles and when I get back in to start it up after about 10-15 minutes the carb is flooded and wont start. After it sits for a while it fires right up. What would cause it to flood out after turning off? The carb is a brand new Holley less than two months old.
Old 10-17-2013, 10:18 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe Bootlegger's Deluxe is offline
Bootlegger's Deluxe is starting off with a positive reputation.
what model of Holley do you have on the truck? I have nearly an identical setup, 81 F150, 4.9, fixing all your vacuum leaks would be issue number one, and then getting the carb properly tuned would be the second thing. It sounds like it is set up too rich, the choke is helping it run while cold, but during warm startup, it floods itself. im not a carb expert, but thats what i am reading...
Old 10-17-2013, 10:59 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
My 80 F150 with the 4.9L/300 does that same thing if I even breathe on the throttle pedal before re-firing it during cooler weather. The electric choke cools off enough to go back to full choke, but the engine is just warm enough that it doesn't need the choke to start.
I have tinkered with the choke, but setting it lean enough to prevent the warm-ish re-fire problem results in harder cold starts, so I just adopted the practice of keeping my foot well away from the throttle pedal during these times. That, and the habit of keeping something handy to wedge the choke open, should I accidentally touch the throttle pedal before it starts.......
Old 10-18-2013, 08:29 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Welcome to the forum, mshefty!
Rogue Wulff is right on. I still believe you might want to check your choke adjustment. You mentioned that you replaced the carburetor two months ago. I bet the temperature has cooled significantly during that time span. Here in the south, it is not uncommon to have to adjust chokes 4X a year [change of seasons]. Where are you located?
While chasing vacuum leaks, look closely at the two bolts which secure the carburetor to the intake manifold [or EGR adapter]. They tend to loosen over time and the new gasket may have settled. A 1/2" wrench works nicely.
I included a link to a thread which might be of assistance.
http://www.ford-trucks.com/forums/11...ent-101-a.html
Old 10-18-2013, 09:34 AM
billest's Avatar
billest billest is offline
billest is starting off with a positive reputation.
sometimes when putting in a brand new carb. you have to tap the side of it with a hammer (ballping)
Old 10-19-2013, 01:00 PM
Thank you for the responses. I wound up having to rebuild the carb and now it is 90% better. Now off to the vacuum leaks. Does anyone know where I can get a complete set of vacuum lines and hoses? I am looking for the hard lines that come off the vacuum tree on the front of the engine with all of the connectors.
Old 10-21-2013, 03:01 PM
Quote:
Take a look at this thread... it has all you are looking for regarding replacing vacuum lines.
http://www.ford-trucks.com/forums/12...uum-lines.html
Last edited by ctubutis; 10-21-2013 at 08:27 PM. Reason: Link to Page 1 of the thread, not Page 2
Old 10-21-2013, 05:34 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
Quote:
That's why Ford was smart enough to use a hot air choke system, and why I encourage everyone to stick to the Ford carburetors when possible. The hot air choke will only choke the engine when it is needed, and only comes off when the engine is ready for it.
Old 10-21-2013, 08:01 PM
Quote:
It has the factory electric choke, with the hot air system as well. Heck, the engine/carb are full stock.
Help need a Radiator racerx6466 S. California Chapter 15 09-05-2015 09:21 AM
floody 2150 78ferd 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-09-2015 04:03 PM
Best way to start, when cold '83 F150 4.9L 6 auto ligito 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 01-07-2015 12:39 PM
86 4.9l wont't run 86trouble 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 04-10-2014 07:34 PM
F100 300 ci Autolite 1100 flooding timber_cruiser 1961 - 1966 F-100 & Larger F-Series Trucks 1 12-18-2013 04:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
