Oil Change interval question
Hello team,
I have a silly situation, my truck averages around 3-4 K miles per year. I used to change oil just before summer every year but this year my truck has clocked less than 2 K miles since last change May 2012. Do you think I need to change the oil regardless? I use Rotella Synthetic every time.
Acids can build up from the effects of internal combustion which in small amounts leak past the ring gaps - etc.
The base oil does not break down, but the additive package has a finite life span, both from a elapsed time and usage point. Some of these additives are designed to counter the acids that build up, although in very small amounts in a modern engine compared to a older engine.
Absolutely no need to change every three months like the oil change places proclaim. Makes them money though and that is what they are in business for, can't fault that as they are a for profit business and does it does no harm to the engine but does make ones pocket book lighter.
Once a year is a good number if you do not drive the truck enough to accumulate the requisite miles for a oil change.
David
David
Hello team,
Instead of using the once a year approach, which by the way I agree with, they will analyze your oil and give you an answer based on true data.
No guessing then.
