Help on Rear Springs & Shackels - Ford Truck Enthusiasts Forums
Old 10-17-2013, 02:03 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
HELP
I bought a set of 3" rear springs & shackle kit for my 52 F-1.
When I go to bolt up the rear of the spring with the shackle the shackle bolt is not long enough to attach to the original inside mount.
There is nothing to support the inside of the upper shackle bolt.
Suggestions???
Thanks,
Tractormanbill
Old 10-17-2013, 02:43 PM
tractorman
Got the answer to Speedway Motors.
They do not have a shackle to fit the 52 F-1 you are supposed to use the original cast shackle.
Sorry for the thread.
Tractormanbill
Old 10-17-2013, 02:58 PM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
What springs is that? Posies?
Old 10-17-2013, 03:08 PM
tractorman
I believe Posies' is correct.
Speedway was not supposed to send me these 2" shackles.
I had about decided to use the original cast shackles anyway.
Tractormanbill
Old 01-25-2014, 01:30 PM
DougofMontana's Avatar
DougofMontana DougofMontana is offline
DougofMontana is starting off with a positive reputation.
Can one of you tell me the secret to getting the shackle pins out of the front mounts for the rear springs? I'm mystified!
Old 01-25-2014, 08:20 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Make yourself a simple puller. Stu
http://www.ford-trucks.com/forums/10...tml?styleid=16
Old 01-25-2014, 09:14 PM
Hi Stu, I got impatient this evening and simply ground off the four rivets on the outside and used a little wedge to pursuade the mounts off the frame. I had considered using the puller technique, but didn't have the proper sized bolt around and seeing as how I live 12ish miles from town I wasn't making the drive. When I go to remount these, I'll be sure to use grade 8 bolts! I looked at the pins compared to the pins show I that thread you gave me the link for and mine look like new compared to those. After taking the steering linkage apart and not seeing ANY wear there, I'm about half convinced that the mileage showing on the speedometer is actual mileage (27,400 miles) I know for a fact the PO owned the truck from 1965 until last August and he never took it off his 50 acre horse ranch. Thanks again for the idea about the puller!
Old 01-26-2014, 12:42 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
There is a hole on the inside of the frame, the pins can be driven out with a long pin punch.
Old 01-26-2014, 08:18 AM
Aussie, the hole for the front pin is blocked by a brace for the cross member, so no hole . I've heard where some guys get under and drill a hole in the brace to gain access, but my way worked.
Old 01-26-2014, 08:22 AM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Quote:
Quote:
Ford basically "forgot" to drill an access hole in that crossmember so that pin could be driven out. They corrected the oversight in later models. For future reference, you can take about a 3/4 to 1 inch hole saw and cut your own access hole in a matter of seconds.
Old 01-26-2014, 09:09 AM
Quote:
Or did Ford provide dealers a shop tool, as did Dodge, to pull the pins without the drama of swinging a hammer under a customer's vehicle? IMHO it makes no sense to drive the pins out when it's so simple to pull them. Besides, Henry was all about saving time on a job which the puller accomplishes. Stu
Old 01-26-2014, 09:49 AM
Doc's Avatar
Doc Doc is offline
Quote:
Good point. Wouldn't you like to have a time machine, travel back to a Ford garage from 60 years ago, and steal one of their toolboxes containing all those specialty tools we see in the manuals, among many other things......
"Tech: I built my AC hoses with E-Z Clip System tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 02-14-2015 12:17 PM
Brake lite switch mounting on swinging peddle assm. tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 01-06-2014 10:36 PM
Need Side Hood Emblem for 52 F-1 tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 11-09-2013 10:41 PM
Refurbishing my 52 F-1 Dash meters tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 10-28-2013 04:16 PM
Starting Red color coat on 52 F1. tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-05-2013 10:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
