Refurbishing my 52 F-1 Dash meters - Ford Truck Enthusiasts Forums
Old 10-16-2013, 09:52 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
I dissembled both meters and cleaned the faces with cue-tips and alcohol.
I had the chrome rings re-chromed.
Sand blasted several of the pieces except the individual meters and painted them back as original with off white, flat black & silver.
I placed cardboard behind the needles on each gage for painting.
I went to Dollar General and bought a color of red nail polish that would look good. My truck is red so I matched the body color. Try not to get a translucent color. I got my wife to paint the needles since she is steadier than I am.
On the front piece for the meter assembly I painted the flat black in the center then found a small juice glass that would cover the black, weighted it down with a socket and painted the outside with the silver. Looks better than original!
The cork spacers were history so I started looking for “0” rings to take their place. First one was too thin, second try was too thick (both were stock size thickness “0” rings) so I went to a business that can build “0” rings from a spool of “0” ring material. They gave me about 10 inches of material for each meter. The size I settled on is about .190 thousands of an inch.
I used file folder plastic colored tags to get amber and red for the speedo turn & high beam indicators.
Here is what they look like when finished.
Upon assembly I found out it is next to impossible to crimp the chrome covers back like they were originally to hold the guts in. In the process I broke one glass cover plate.
I am now holding the units together with slight pressure and using clear silicone to seal and hold the assemblies together instead of crimping them.
The two assemblies look like a diamond in a goat’s *** after they were finished and will really look nice when installed in my red dash.
Anyone have a broken speedometer or gage housing around that has a good glass I could use to replace the one I broke??? If so e-mail me at tractorman@billstractor.com.
Tractormanbill
Old 10-16-2013, 10:11 PM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
Looks good, too bad the glass broke. How did you do the faces? Did you have a stencil?
Old 10-16-2013, 11:04 PM
pineconeford's Avatar
pineconeford pineconeford is offline
pineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to behold
I have one for you -PM sent.
Old 10-17-2013, 12:26 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
Nail polish, wish I'd thought of that when I did mine.
Old 10-17-2013, 12:38 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Nicely done, Bill! Are your turn signal arrows actually hooked up?
Old 10-17-2013, 01:00 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Nice job on those. They look great.
Old 10-17-2013, 02:07 AM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Pinecone,
Reps sent for stepping up and offering him a new glass when he never even asked for one.
Bill,
Gauges look great.
Old 10-17-2013, 07:34 AM
tractorman
I didn't have to repaint any of the numbers on the gages just cleaned them up.
The biggest problem on the re-build was finding an "0" ring the correct thickness to replace the cork gasket plus the crimping on reassembly.
I started to reset the speedometer to 00000000 but chickened out since I only had one in case there was a problem. I used to do this all the time 40 years ago back when it was not against the law. I generally don't like to work on nickey/nackey small stuff like this anymore.
I'm re-wiring the whole truck with EZ wiring kit with a new steering column so I don't know why I cannot get the turn signals to work since I have left & right individual bulbs in the speedometer housing.
Thanks for all the offers for glass. I have contacted Ilya since I am obtaining other parts from him but have not heard if he has one or not.
PS: Tom B. e-mailed me that he would send me a glass. Much thanks!!
Tractormanbill
Old 10-17-2013, 08:50 PM
Yep, I got a free one on the way to Texas for Bill. In return I asked for the names of good BBQ joints in the San Antonio area. I get down that way every few years or so.
If any of you like meat & sauce like I do....it's a fair trade for that knowledge!
Tom
Old 10-17-2013, 09:22 PM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
Great job. Are using the original sockets for the turn signals? If so, they ground out at the mount. From the pic, it may be that you are preventing that with the o rings. My 2cts
Old 10-18-2013, 04:39 PM
OldGrayMare's Avatar
OldGrayMare OldGrayMare is offline
OldGrayMare is gaining momentum as a positive member of FTE.
Looks great, you did a rally nice job on those.
Old 10-18-2013, 06:56 PM
SCRAPHEAP51's Avatar
SCRAPHEAP51 SCRAPHEAP51 is offline
SCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to behold
Looks really nice. great job on the refurbish.
Old 10-28-2013, 05:09 PM
tractorman
Here is the finished product after Tom in Main sent me a glass.
That is a reflection on the speedometer gage, not a broken glass.
The biggest problem of all was coming up with an "0" ring to replace the cork gaskets that were gone! The thickness of the "0" rings was 3/16 or .188 dia. BUNS-N ORING CORD and I cut it to length
Be sure if you rebuild to use silicon to hold the unit together rather than trying to crimp the case!
Tractormanbill
Old 10-28-2013, 05:16 PM
Just another Joe
Those look brand new Bill. Good work!
"Tech: I built my AC hoses with E-Z Clip System tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 02-14-2015 01:17 PM
Help on Rear Springs & Shackels tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-26-2014 10:49 AM
Need Side Hood Emblem for 52 F-1 tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 11-09-2013 11:41 PM
Starting Red color coat on 52 F1. tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-05-2013 11:09 PM
Need front frame horns for 52 F-1 tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 40 10-06-2012 11:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
