Variations of the 460? - Ford Truck Enthusiasts Forums
Old 10-16-2013, 08:55 PM
NidStyles NidStyles is offline
NidStyles is starting off with a positive reputation.
Has anyone done a documentation of the variations of the 460 in totality? I don't just mean the change from the Carb'd to EFI variants, but the entire thing from bearing and main changes to well everything.
I've done a search, but I did not find anything that was truly conclusive. There must be a book about this somewhere or something.
Old 10-16-2013, 11:15 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE is gaining momentum as a positive member of FTE.F-250 WARHORSE is gaining momentum as a positive member of FTE.
Well, nothing that I know of, but early on were c8 heads and 10.3 deck, sorry rods, then went to the c9 head for 69, same thing though, then 70 came the dove heads, 71 was a 10.322 deck, went from the dove block casting to the d1ve casting, then 72 came the really really sorry d2 heads along with the retarded cam timing, then 73 was the debut of the d3 heads. 79 was a running change for internal balance to external balance and the deeper cylinder block that was the last casting, D9, as well as the football cut rods, somewhere in there the 460 went from Lincoln to f series, 83 was the first manual trans ever. 88 was the first EFI and 5 spd option as well as back to the regular straight up cam timing. 92 was a revised EFI system, and that got us to the last one in 97. Theres some odds and ends I have missed but that sums up the 460 for it's 30 year production.
Old 10-16-2013, 11:32 PM
97puller's Avatar
97puller 97puller is offline
97puller is starting off with a positive reputation.
460ford.com is good website for bigblock info
Old 10-17-2013, 11:13 AM
Thanks for the information guys, especially that site.
Duraspark Variants? bruno2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 08-24-2015 05:54 PM
How to make a carburetor part of the interior decor ctubutis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 04-02-2014 10:16 AM
Water pump question 85lebaront2 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 02-10-2014 04:52 PM
Weird Cooling Issues Roasted7 6.0L Power Stroke Diesel 2 07-28-2013 10:27 PM
C-6 output shaft variations redroad 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-24-2012 06:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
