a bag full of interesting
welp, Ive got a new problem. My truck has an irritating wobble at 35-40 mph. Litterally as soon as I hit 35 and until I hit about 45 mph, my truck's front end wobbles and vibrates and I dont know why. Ive got brand new tires all around, all weighted and balanced correctly, the front end is all tight (jacked it up, grabbed the tire and tried to shake it, didnt move much at all), the front end is greased, the wheels bearings are good (I just had them out when I did the front brake rotors. They are smooth and almost overpacked with grease). I have new front brake rotors as well as one of the old rotors was warped.
Any ideas? Maybe a tweaked rim? I dont see them as bent and the tires seal fine so I dont think either of them are dented...the lugnuts are tight too...
Its only for the most part while Im driving at the speed listed above. Whether Im on the gas and accelerating, or coasting to a stop, the vibration is there. It feels like an up and down kind of vibration if that helps...accelerate up to about 43-45 and above or drop to under 30 and it goes away completely... what is it?
How are your shocks? Is it 4x4? Can you jack up all four corners and spin the tires to look for wobbling?
I'm thinking that your shocks are worn out and you may have one or more tires mounted crooked on the rim. It has happened to me a couple times.
It can be corrected if caught soon enough but after a while the tire will take a "set" and will need to be replaced.
Gabriels are decent. Rancho. Lots out there to choose.
When I was in high school I had a '73 F-100 that got where it would shake violently about that speed. I mean to the point that stuff would fly off the dash and I couldn't do anything but hit the brakes and stop. Turned out that the king pins were shot. Replaced them and also the radius arm bushings and had no more trouble.
Yep im 16 and mine does the same thing.. i mean stuff shakes off the dash and it loosens up my whole truck lol.. it goes right away at about 43 or when i have a heavy trailer. Everyone at school is scared to ride with me
joshofalltrades
23
09-08-2013 07:45 PM
