460 engine code??? - Ford Truck Enthusiasts Forums
460 engine code???
Old 06-20-2003, 12:48 AM
S.Kelley S.Kelley is offline
S.Kelley is starting off with a positive reputation.
460 engine code???
I need help with an engine code on a 460 that I have. The block code is DIVE-A2B. Can't seem to find anyone that can decode that for me.Local dealer and largest salvage yard can't. I need to know year,HP and torque. Any help would be appreciated..Thanks.
Old 06-20-2003, 01:03 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
460 engine code???
D1VE-A2B
D=the decade D = the 70's
1 not I
1 is the year of the decade 1 = 1971
V = Car line designed for V = Lincoln
E = Ford's department of design
E= Engine
A2B = Change-up of part design letters/number
this has had numerous design changes by the time is was cast
Where are the numbers between E -????- A2B
9425 ? = Intake manifold
6015 ? = Engine Block
Where are the actual *date of cast* characters?
ie: * 1B25 *
Old 06-22-2003, 12:23 AM
460 engine code???
Hey thanks Denis. There were no #'s between the E and the A2B.
I got that code off the block by the starter. Should there be more #'s there? Also any idea what the HP would be on that engine?
Thanks again for your help!......Steve.
I pulled engine code18...need translation henryFord460 1987 - 1996 F150 & Larger F-Series Trucks 21 07-01-2016 03:40 PM
weird engine code xsfg 1987 - 1996 F150 & Larger F-Series Trucks 3 10-09-2014 03:58 PM
Please help with codes!! shawbran 1987 - 1996 F150 & Larger F-Series Trucks 6 09-06-2011 07:41 AM
PO-460 Code? dentaldave 6.0L Power Stroke Diesel 9 09-01-2009 05:37 PM
Engine Swap 460 to 7.3 lundchief 1987 - 1996 F150 & Larger F-Series Trucks 4 06-10-2006 12:39 AM
Tags
1b25, 460, big, block, code, codes, engine, escape, ford, intake, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
