56 F-100 Power Steering - CPP vs Toyota - Page 2 - Ford Truck Enthusiasts Forums
Old 10-19-2013, 02:12 AM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by SPDBGY2000 View Post
^^^^ I have the same question about the steering column ^^^^
Here's how I did mine:
http://www.ford-trucks.com/forums/97...mn-repair.html
Old 01-08-2014, 12:56 AM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
Has anyone tried this conversion with the stock 3 on the tree?
I figure it will be to tight with a rag joint but imagine that a borgeson joint that is allowed to slide partly into the column tube might work. Hence having the bushing between column tube and steering shaft above the borgeson joint......
Any thaughts appreciated
Toyota Power Steering Install (1956 F100) Schuyles 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-21-2016 07:00 PM
Power steering conversion rio68 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-21-2015 01:39 AM
CPP 400 Power Steering Install F100Jay 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-01-2015 06:42 AM
CPP Power Steering Assist F100 fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-15-2015 11:25 PM
CPP Power Steering Kit Installed 53OlderThanMe 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-13-2013 11:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
