Good Day Central Oregon - Ford Truck Enthusiasts Forums
Old 10-16-2013, 01:01 PM
Morgan's F-250 Morgan's F-250 is offline
Morgan's F-250 is starting off with a positive reputation.
I am new to the chapter and wondering with whom I could ask questions to.
I live/work in Bend and my truck is a 76' F-250; FE 360; Camper Special, recently back from the dead, only to be dead again.
I think its a selector switch for the fuel tanks, but alas, I could be wrong.
This engine has a lot of vacuum lines, breather cap, emission controls. Nothing like my ol' 69.
So please point me in the right direction
Morgan's F-250
Old 10-16-2013, 01:57 PM
bertha66's Avatar
bertha66 bertha66 is offline
bertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud of
Welcome Morgan, I'm in Prineville and work in Redmond. And I have a 76 F250 4x4 Hi-boy truck. My fuel valve is fixed so when it is pointing to the back of the cab: it is on the main cab tank, pointing at the drivers door; it is on the left tank and pointing at the passengers side; right tank. If your valve is under the cab on the drivers side; follow the lines and see which tank it is drawing from.
Old 10-16-2013, 05:11 PM
TinyWonder's Avatar
TinyWonder TinyWonder is offline
TinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to behold
Welcom aboard Morgan. Be sure to chime in on the B/S page when you get a chance.
Old 10-16-2013, 06:49 PM
RE: Bertha66
My truck has the dash switch aux/main. Mid-ship tank and one over the rear axle. I've found the solenoid on the frame rail driver's side, but have no idea if the electrical is solid.
What other avenues is there???
Thanks in Advance
Old 10-16-2013, 07:47 PM
Seabiscuit-P3's Avatar
Seabiscuit-P3 Seabiscuit-P3 is offline
Seabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputationSeabiscuit-P3 has a superb reputation
First, I would make sure there is sufficient gas in each tank to fire it up. If there is, try starting it with the tank selector in each position. If it is still acting like it is out of gas, it probably isn't the selector valve. Even if the selector solenoid is bad, the valve to one tank or the other should be open allowing fuel out of the one tank.
Check the fuel pump before you get too carried away.
Look at the floor between the edge of the seat and the drivers door and see if you have a valve there. Our farm truck has the "Aux-Main" Toggle switch on the dash, but it only controls which tank the gauge is reading. The tank flow control valve is a manual gate type valve on the floor at the above location.
My 78 was all electric but it was a rocker switch labeled "Front / Rear" as is my 96.
If you are 100% electrical, you are going to need a multi-meter and you are going to have to make sure the connections are corrosion free and the fuses are all good.
Oh yes, Welcome aboard and be sure to visit the BS thread.
Lets see stereo setups pic request 2tone250 1973 - 1979 F-100 & Larger F-Series Trucks 25 01-21-2015 08:50 PM
Morgans Corner 1979bronco Virginia Chapter 0 05-30-2014 06:30 PM
Very sad news. fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-16-2013 06:10 PM
1951 F-1 clutch linkage for 4 speed swap Trey_Morgan 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-15-2013 05:51 AM
Offenhauser 5774 intake 2tone250 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-13-2012 02:37 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
