2003 F250 7.3 transmission service - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-16-2013, 10:03 AM
Tact's Avatar
Tact Tact is offline
Tact is gaining momentum as a positive member of FTE.
I've owned this truck since new and I just turned 100K miles. Here lately when I accelerate slowly, my transmission shifts and I hear a chatter, usually from 2nd to 3rd gear, or from 3rd to 4th. When I shift under normal acceleration it shifts fine.
While checking my service records I found that I had the transmission first service at 32K mile, but it didn't indicate whether I changed the filter. With that low of mile I probably didn't, just the fluid change.
Next I had the transmission flushed at 68K miles.
Now I think I am due for another service and I am really confused as to what the proper service to be done. Some say all I need to do is drop the pan and change the filter, then refill with 8 quarts. Others are saying that is not correct and I need to flush the system.
Also, do I have an external filter? Some shops are not aware of an external filter, and neither am I.....but that doesn't mean much either.
Regarding my chatter when shifting, do I need to just add an additive for this issue?
Old 10-16-2013, 10:15 AM
Tact's Avatar
I should have posted this in another section....sorry.
Old 10-16-2013, 09:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
You should change the fluid. Not just what's in the pan, but all the fluid. Here's how. Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
The internal filter is the only filter the transmission has. It is not a very fine filter and it is good for the life of the transmission. You don't need to change it until the trans is rebuilt.
Old 10-16-2013, 09:42 PM
Tact's Avatar
So if I take it to a shop, a flush would be all that is needed, correct?
Old 10-16-2013, 11:06 PM
ggazz50's Avatar
ggazz50 ggazz50 is offline
ggazz50 is starting off with a positive reputation.
I also has a shudder when shifting at slow speeds. I was due for service so I took it to my local Ford dealer and they flushed and refilled with new fluid. The trans shifts great now.
Old 10-17-2013, 08:19 AM
Quote:
Yes it is. No chemical flush, just new fluid.
2003 F250 7.3 transmission service Tact Clutch, Transmission, Differential, Axle & Transfer Case 2 10-18-2013 02:54 PM
4r100 post flush abnormalities Biscayne Clutch, Transmission, Differential, Axle & Transfer Case 1 10-18-2013 09:41 AM
2003 F250 7.3 transmission service Tact 1999 - 2003 7.3L Power Stroke Diesel 7 10-17-2013 07:05 PM
OK Lets play diagnose this problem brockinfla Expedition & Navigator 13 10-30-2006 03:39 PM
1997 F350 Transmission shifting and heating problems VargasB 1994.5 - 1997 7.3L Power Stroke Diesel 1 05-14-2006 11:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
