Fuel Gauge
these floats and or sending units in the tank are mounted on the back side of the pick up foot. The tank also dose not have any baffles in it.
If parked nose down you will notice low fuel on ur gauge. If nose up it will show full or fuller than you are.
OP..... Most likely if you ran it below a 1/4 tank before filling up like Bill mentioned it probably got stuck for a bit then freed back up.
Watch your mileage per tank and if it keeps reoccurring then might need to drop the tank and inspect, also a good time for hutch and harpoon.
The issue I'm seeing is this... and it's happened twice so far. With a full tank of fuel... driving down the street the gauge would immediately go to emply, fuel light comes on. Pull over, turn engine off, restart and fuel guage would read normally again. Did the same thing this morning.
Thanks!! Kind of I guess. I guess I was looking for the smoking gun... I don't want to go thru the trouble of dropping the tank and not finding the problem, you know what I mean?
hangon2me
03-01-2009 07:40 AM
