2002 F250 CCLB Build
#736
You make a very good point. To make it sound better, we are typically going between 10 and 20, we only drink light beer, and we always where helmets. Still not ideal, but we have a good time. The goal of every trip is that no one gets hurt 😉 The most entertaining part is that 3 of us are 28, everyone else is in their 50s and 60s. Really makes for a good time. Amongst the group, I've been given the nickname "Captain Slow"....
#737
Steering Question
So I drove the F250 for the first time in a few weeks this past weekend. I am noticing that some times the steering wheel doesn't completely want to go back to center while driving. It just hangs up a little bit and it doesn't do it all the time. Thoughts on what it may be? Here are the facts:
1. Original steering Stabilizer is still on it.
2. It seemed to still do it with hubs locked and unlocked.
3. There is not whine from the power steering pump.
4. There is a small fluid leak in my steering box. It is coming out the spline shaft for the pitman arm.
5. I just greased all tie rod joints and my upper ball joints. Lower ball joints do not have a grease fitting.
I had a similar problem on my Ranger and the culprit was the outer u-joints. I replaced everything in the steering system before I figured it out. I was going to try and take a more direct approach here, especially since the parts are a little more pricey.
In other news, I helped a buddy install a light bar on his quad. He did not take any measurements, or figure any wiring out. He bought a 40" light bar and said its going on my quad.
After some brainstorming, we made some plate brackets for the supports and I re-purposed the 30A power steering circuit for this light bar (which draws 25 amps....). Added a 30 amp toggle switch to the console and we were all good. So what good would this bee without pictures....
The only downside here is this bar draws more power than his quad generates at full power... so if he is using it, he is draining his battery
#740
I have 115k and I'd bet they are original. I was looking at some Moog greasable joints on RockAuto for $30 each. I'll probably replace these in the coming weeks. Its another opportunity to grease my wheel bearings again and maybe get my rotors cut. What is the deal with these axle seals? I was looking at them when I was greasing my ball joints. Do they just fall apart?
#742
What brand of seals did you use?
I was looking at the Spicer. To be honest, I have no problem greasing them every 3k. I'd much rather know that they are getting fresh grease. After my findings with the dry unit bearings on my truck when I bought it... I'll take grease. I do not put a lot of miles on it, so 3k would only be 2 or 3 times a year.
#744
Ok. I'll see if it passes inspection as is and then deal with it.
Yes, I have done it once each year with about 10k miles in between. The first time I did it, they did take a TON of grease, but it completely changed the feel of the bearing. You could tell just how thirsty it was for some lubrication. Only needed a few pumps the second time. That RiffRaff fitting is worth every penny.... they only thing I wish was difference about those bearings is that they had a tapped hole and plug on the bottom so you could pump new grease in the top and the old out the bottom.
#748
#749
