66 Ford F100 Worth Asking Price
#61
Yeah Definitely, every penny counts and most importantly you have to feel comfortable with your decision to purchase it for an amount. Because if you over pay then when you are fixing it up you may feel overwhelmed $$$ wise. Also that big dent it has on the door, it is AMAZING what an air hammer can do do dents from the inside out and I've done plenty of it on mine. One Question How did you post those pictures here on the thread I have not figured it out yet ????
But here's hoping. I think it'd be a good first truck for me - something to wet my whistle.
#62
1966
I doubt he'll accept 1500 - he's probably pissed I reneged on my offer but today was the first day I got to see it in full daylight (first time I saw it I had to wait for him for over an hour and the sun had set).
#64
Hey Jesse,
Saw the pics you posted...I will say one thing...Short bed slicks are totally bitchin'. There is one in my town, exactly the same
color as mine, and although rough, would be a riot to restore. I wouldn't worry about the door-but that cab corner would be a
challenge...a lot of hammering, welding etc...but it could be fixed. If it were me, I'd find a donor section from another cab and
seam it in...or even a replacement cab, but I do live in the Communist State of California where these trucks are plentiful.
If you could nickel him down to 1600$, it may be worth it...
One thing though, it looks like the owner treats it like a storage container...anyone who does that to a slick should be punched......
he's clearly a dip-sh%t who is clueless on the value.
#65
Hey Jesse,
I sent him a long message that boiled down to "I'll take it for $1500." And I think he'd be short sighted not to take $1500. But you know how people are.
I don't know what I'd do about that cab corner. A replacement cab def isn't it.
#68
That's a silly statement. I drive mine at 70-75 every time it's on the highway; it drives just fine. If the steering isn't worn out and everything is as Ford intended when it left the line, it will be fine. This isn't a 1930 Model A we're talking about.
#69
Menace on the highway:
4 cylinder 1928/31 Model A - 1932 Model B - 1933 Model C: Top speed 45 MPH
Henry was stubborn, long after other automakers introduced hydraulic brakes, Henry finally got around to it in 1939.
Prior years, Ford/Lincoln used cable operated brakes, it was a full time job keeping those cables adjusted properly.
#70
It isn't about when things are going right. It's about when things go wrong. No seatbelts or lapbelts at best....a column that is unfriendly and a back window waiting for a head to hit it combined with a high roll center, 50 year old suspension and best yet....4 wheel drum brakes. When things go wrong and you have to react, things can go bad quickly. We are simply used to different standards today. In the 60's, a lot more people died in accidents, and it was pretty much accepted as coming with the territory. I don't think it is silly to desire better than that today for an every day driver. I don't even want to start in on reliability of vehicles today that can run at 70 mph for 200,000 miles and still run like a top. If a fellow puts 15,000 miles on that truck per year, how often are we looking at tuneups? Going for a weekend drive somewhere in the truck is one thing. Going to work in traffic every day is another.
#71
I don't think you are at all wrong for considering this truck. As a second vehicle/casual fixer upper it's not a bad thing.
As a profitable investment I think you would do better buying pork bellies, bridges and ocean front property in Arizona from me.
I see $50,000 pickups roll off the lot. In 5 years they are worth about half that. So which would you say is the better deal?
#72
1966
Hi, I will agree with (DDAVIDV) I Drive my 1958 Ford F250 70-75 all the time up and down I-75, as long as the steering is not shot and too Loose you will be fine and if it is you need to rebuilt your steering box. My 58 cruises and screams down the highway with the FLOWMASTER I put on it, PLUS I installed a steering stabalizer on mine and it helps alot when you are going higher speeds especially in the BUMPS. Hopefully he reconsiders for you, if he does that 66 is a nice project for the first old Truck. Also mine is 4 speed on the floor but my 1st gear I dont use it's a GRANNY GEAR so I only use 2nd 3rd & 4th and it rides great.
#73
BUT...are drum brakes, properly maintained, really that unsafe?
#74
Let's put it this way since I have drum brakes. You will never catch me on the freeway around here in any traffic because if it all stops quickly I know I won't even if only doing 50. On top of that there is always going to be a moron that pulls right in front of you, at the last second, and who assumes you can stop on a dime. More likely on the dime in his pocket.
#75
