1952 F1 Under floor brake booster and master cylinder
Can some of you guys with a 48- 52 post pictures of how tour brake booster is mounted and how close to the transmission crossmember it is or if you had any fit issues?
I had that setup on a '56 I liked it . If I did it again I would use the remote reservoir.
I did not like the fact that I ad to check the fluid level from below. I do not have access to a lift........
