ball joints
Tools:
Torque wrench, good pair of snap ring pliers, OTC 6697 Knuckle seal driver, Ball joint press with adapters. A good 13/16 socket, I used an impact socket.
A good tip would be get the correct snap ring pliers.
It's not really a hard job. A few trouble spots for me the DIY, removing the snap ring, removing the knuckle seal, installing the updated axle to axle tube dust seal.
There is a sequence for torquing the ball joints. Torque bottom 1/2 way, then torque top, then torque bottom. I have the specs if you need them.
It took me 1 1/2 days to do driver side, and 1 day to do pass. side. It was my first time doing this and I took my time.
If it helps I did mine one side at a time. I do work slow but thorough. Also I had to hunt down a buddy to borrow the snap ring pliers. This is why it took a day and a half on the driver side.
Two weeks later I did the pass. side. It took a good day, and I knew what I was doing.
I hope I did not scare you out of it.
One thing to remember: If you have the push button 4x4 they are vacuum operated so you need to re-install the hub air tight. It's worth it to replace the o-ring seal and hub gasket, and possibly the knuckle seal.
If I had just dropped $1100 on new tires, I would be doing my best to replace both sides the same day and taking the truck the following day to get an alignment. Someone posted on here a few days ago about ball joints and they said it cost them $600 in tools and parts to do both sides and then they paid for an alignment. I'll have to find that post. But if so... you may come out better just paying to have it done? But if you plan on doing both your trucks, maybe this is a good time to learn and the next will be easier! Going to search for the post...
Here it is and I guess Blade says you don't have to do an alignment? hmmmm:
https://www.ford-trucks.com/forums/1...ll-joints.html
as long as the Alignment "Adjustment" is OK to start with
and the adjustment isn't Lost during repair
I have Aligned a few cars with a Good old tape measure and driving it
The first time I did it I must have adjusted it 20+ times LOL till I got it
A pretty good indicator is if you can drive down the road Straight without the steering wheel Cocked
Theres A lot of Toe adjustment in these But the Camber is very little if any OEM Parts (Sleeve) and when you torq the Ball Joint the Camber adjust goes to where it wants just about at least my 2003
The last Alignment I did my wife wrecked the car
Knocked the Front tire about Clean Off
In fact I finished taking it off with a SawZall LOL
But I Put it back into alignment in fact the Side the tire got knocked off ended up wearing the Tire out more even then the other side that had no damage. Each side was independent adjustment of one another Not like our trucks
FWIW, I just got new upper ball joints as part of an accident rebuild. The RWD truck had 150kmi on the originals, but still drove perfectly. After getting hit on the left front wheel and having the body repaired, it pulled to the right. The alignment shop said the ball joints were too worn. The body shop replaced them and it still pulled. They finally replaced the left wishbone and now it goes straight down the road.
How many miles are ball joints normally good for?
jack vines
jack vines
4WD? If so you will NEED a half shaft seal installer. You are never gonna get it on there despite what others claim. I made my own because the OTC or factory tool is expensive. I made mine from steel plumbing pipe and a floor mount plate. I'll see if I can find a link.
Ford Super Duty Knuckle Seal Tool - AKA OTC 6695 | Superdutypsd.com
