Broken Ignition Lock Cylinder, 1988 F-150 - Ford Truck Enthusiasts Forums
Old 06-19-2003, 10:33 PM
Robinmblind Robinmblind is offline
Robinmblind is starting off with a positive reputation.
Unhappy Broken Ignition Lock Cylinder, 1988 F-150
The ignition lock cylinder on my 1988 F-150 is stuck in the "lock" position. If I could get it to the "run" position, then I know how to remove and replace it. But that's now out of the question as I have already buggered up the cylinder by trying to drill it out with, so far, no success. Does anyone here know how a Ford dealer would go about removing such a broken lock cylinder? I'm guessing there's a plug in the housing that must be drilled out to access the pin holding in the cylinder.
Thanks.
Old 06-19-2003, 11:22 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
Is it a tilt column? If so, the pin to drill is right below the lock cylinder. If it's a non-tilt, you have to pull the steering wheel to drill the pin.
I've never done it, but you can find detailed instruction at the site where these pics came from - Chilton's
Old 06-20-2003, 01:14 AM
Thanks, Steve83, for your reply. Yes, it IS a tilt column and I have already removed the steering wheel and the turn signal assembly. Those are nice drawings you included but I'm a bit confused. You see, I can't move the lock to the "run" or "on" position. Does that matter? Should I go ahead and drill at that same place anyway? As long as the lock can be moved to the "run" position, then removal of the cylinder is straightforward.
Please let me know if you think I should drill into the access hole even if the cylinder is stuck in the "lock" position.
Bye!
Old 06-20-2003, 01:21 AM
steve83's Avatar
Click the "Chilton's" link in my previous post and look up the instructions. They tell exactly what to do.
Old 06-20-2003, 01:26 AM
Wow! That's a great Web site! Yeah, it DOES look like I should drill through the access hole. I've already drilled through the lock cylinder.
Thanks very much for the reference. I'll let you know tomorrow if I get that thing out of there.
Old 06-21-2003, 01:48 AM
Thumbs up Broken Ignition Lock Cylinder, 1988 F-150
OK. Just a follow-up to let you know that the information online at the Chilton's site was accurate and I was, indeed, able to extract the broken ignition lock cylinder in the manner described there.
Thanks again to Steve 83.
Old 06-14-2008, 12:46 AM
GuyWithAnOldFORD GuyWithAnOldFORD is offline
GuyWithAnOldFORD is starting off with a positive reputation.
Cool broken lock cylinder removal - non-tilt
My 1988 F-150's lock cylinder has broken... so I can't turn the ignition ON to remove it. The previous posts said to drill out the access hole, but I can't find a diagram to show where. I have the steering wheel off already but don't want to drill the wrong thing! The very tip of the cylinder broke off inside the housing and the center of lock cylinder came out, leaving only the larger piece of the cylinder in place. What a mess.......
I tried the website listed as well, but it's not a good link. And the Chilton website now charges to look at anything, unless I haven't looked in the right spot. So if someone can show me a diagram and point out what to drill or tell me what else to try, I'd really appreciate it!!!
Michael
Key broke off in ignition lock cylinder akg123 1987 - 1996 F150 & Larger F-Series Trucks 6 12-14-2015 04:36 PM
'08 lock cylinder Late96 2004 - 2008 F150 4 01-21-2015 05:23 PM
Ignition lock cylinder woes NotEnoughTrucks2014 1987 - 1996 F150 & Larger F-Series Trucks 0 10-29-2014 11:13 AM
96 Ford Ranger XLT Ignition Key stuck in off Position aveluca Ranger & B-Series 4 03-18-2014 08:55 AM
Ignition Lock to rack/pushrod timing tonkyman 1987 - 1996 F150 & Larger F-Series Trucks 11 07-02-2013 10:40 PM
Tags
1988, broken, cylinder, f150, ignition, lock, remove, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
