Long Bed to Short Bed Conversion - Ford Truck Enthusiasts Forums
Old 06-19-2003, 10:23 PM
81fordtruck 81fordtruck is offline
81fordtruck is starting off with a positive reputation.
My 81 ford has a major rust problem in the rear bed corners, and a little over the wheel wells. I plan to repaint it this fall in AutoBody at school, and figured I would save time to buy a new bed. And then I got to thinking, well, if I buy a new bed, I might as well make it into a short bed. Has any one done this, and if so please let me know what I'll need to do. I think I'll just have to bolt the shrt bed over my rear tires, and cut the frame and reweld into place. I know I will need new driveshaft, exaust. Any other suggestions would be appreciated greatly. Thanks Jared
Old 06-19-2003, 11:21 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I am not sure on this, but you may need to do some measuring. The difference in the bed lengths may be in front and behind the wheel well, not just in front of the wheelwell.
Old 06-19-2003, 11:43 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
The frame is different for bed length (and cab length, too) so you can't change.
Old 06-20-2003, 11:10 AM
ok, i'm gonna do some measuring and see how many differences there are, and if the difference is in the front of the wheel well, i might try it if i can find a cheap bed, but i dont know yet.Thanks for your responses.
Old 06-20-2003, 07:43 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
The wheelbase is 16" shorter on a short bed, and, you will find the extra 16" between thefront bed bolts and the bracket the parking brake cables hook into. On a FlareSide, the bed is 18" shorter overall, but, that's just in sheetmetal, the frame is the same from the axle back.
And, Steve, don't say it can't be done.... It can, it's just not something the average do-it yourselfer can tackle. I'm planning on chopping my F250's chassis again and making it into a short bed... I started with a 155" wheelbase, and, will finish at 117", unless I feel like building a Bronc.... LOL
Evan
Old 06-20-2003, 10:27 PM
Hey, thanks alot, i thought it could be done, but didnt know if my facts were strait. I'm planning on doing this in Auto Body class at my highschool. If i cant find a short bed, i may just buy patch panels to fix the rust, but this may be more work than the short bed,lol. Thanks alot,..Jared
Old 06-22-2003, 04:08 PM
Txquadhunter24's Avatar
Txquadhunter24 Txquadhunter24 is offline
Txquadhunter24 is starting off with a positive reputation.
A friend of mine done this to one of there trucks. To complete the work You'll have to shorten the Frame in front of the rear end channel and you'll have to take some off the end of the frame. How much i don't know, I just watched them do it at times while i was there. so it can be done.
Old 06-22-2003, 05:59 PM
bigreave's Avatar
bigreave bigreave is offline
bigreave is starting off with a positive reputation.
I have seen One guy in my home town with a super cab long bed but with a short bed it had a half foot gap between the cab and the bed but it did work. Plus a buddy of mine took a 83 longbed chopped the frame and made a swb stepside
Old 06-22-2003, 09:43 PM
ok, i planned on just taking the extra frame out from in between the cab and bed. My dad used to have a 72 ford that was made into short bed, and it was taken out here. couldnt tell it was ever a long bed.
Old 06-23-2003, 12:03 AM
82F100SWB's Avatar
81: on the 80-up trucks, you have to cut between the front set of bolt holes for the bed and the axle kickup, if you drop the bed on, it won't bolt up at the front, well, you don't have to, but, it's alot easier to use those holes for measuring.
Evan
Old 06-23-2003, 08:52 AM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
Thumbs up Long Bed to Short Bed Conversion
Just a thought - Do you have a swing bearing in your long bed? I have cut down the frame before, removed the swing bearing and made just one driveshaft. Gotta rework the parking brake cable, brake lines and gas lines, then double up or wrap up the wiring. The gas lines all depend on if you have one or two tanks, of course. You have the right idea, though, measure and mark, and even do a little layout first - you can do it.
Old 06-23-2003, 12:36 PM
hey, thanks for all the tips, i got dual tanks now, but if i find a short bed with only a single, i will have to make it single. What is a swing bearing? I've never heard of this before.
Old 06-23-2003, 01:12 PM
85F_150driver's Avatar
85F_150driver 85F_150driver is offline
85F_150driver is starting off with a positive reputation.
is on a 2 piece drive shaft if you have a 1 piece ur alright but on a 2 piece it looks like a horse shoe flattened out with the drive shaft going through it.
Ben
Old 06-23-2003, 10:30 PM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
just be prepared for quite a bit of work and unsuspected surprises. Me i would just find a good replacement bed with little to no rust and use that instead. It will take a buddy and an afternoon or so to do the swap then you can paint away.
Old 06-23-2003, 10:42 PM
F2504x46.9L86 F2504x46.9L86 is offline
F2504x46.9L86 is starting off with a positive reputation.
I would think you could just take brake lines gas lines, etc. from a short bed and put them on there or better yet look for a short bed truck that could match the cab frame... but idk I'm new at this.
Dan
Where to buy new take of or used bed? BlueBeauty 1999 to 2016 Super Duty 4 06-12-2016 08:29 AM
1969 f100 ranger 302 460jared96 1967 - 1972 F-100 & Larger F-Series Trucks 12 04-05-2016 10:21 PM
Twin-I beam Prices? Harkijr 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-23-2014 06:08 PM
New Nevada guy '77 Dent New Member Introductions 1 08-15-2014 11:05 AM
extended cab SHORT bed 460jared96 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 35 06-07-2014 12:03 PM
Tags
1972, 1978, 4x4, bed, cab, conversion, f100, f150, f250, longbed, make, regular, short, shortbed, wheelbase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
