Long Bed to Short Bed Conversion - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 12-25-2012, 08:30 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
That nice straight rust free(looks rust free) 8 ft bed would bring a pretty penny over here in the east.
  #62
Old 12-25-2012, 08:59 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
If you dont know how to weld, the making a 2wd into a 4wd is A LOT easier.
It is a matter of unbolting the 2wd front end and bolting in a 4wd. Then swap the 2wd trans for a 4wd one and bolting on a t-case. It can be done in a weekend
  #63
Old 12-25-2012, 09:12 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Quote:
Originally Posted by MW95F250 View Post
I'd just leave the frame alone. Cutting it would be too much of a pain in the rearend. Just find you a good longbed and drop it on. Plus cutting and welding together a shorter frame weakens it and lowers the capabilities of the truck.
Can't argue the hassle of getting it right and proper reinforcement, but if again done correctly, the weight capability does not change. Semis and straight trucks get frame modifications done all the time, but the key is doing it right. Just cut and splice is not getting it right. You have to fishplate at a minimum. The biggest and most important factor is keeping it straight. If you don't get it back together right, you will make a permanent dogtracker.
  #64
Old 12-25-2012, 03:31 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Off Topic: This thread makes me want to build a Longbed flareside in this year model.
Would have to find a 8' flareside Bed from a 1973-1979, and put 1980-1987 tailgate, and 1980-1986 fenders on it. Or fabricate the bedsides to length. Would make people look twice at the vehicle, and have a cool factor of +10 to me.
If you wanted a Flareside and that's the reason why you want a short bed, AKA, the Red F-350 that the frame was shortened above, that would solve that problem without as much hassle.
  #65
Old 12-25-2012, 03:52 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
You want a head tuner, make something like this.
Saw this for sale a year or so ago, saved all the pics, found it so cool.
1988 F350 4x4 Diesel, reg cab long bed, frame shorten, home made step side bed.
  #66
Old 12-26-2012, 04:34 AM
That had to ride AWESOME
  #67
Old 12-26-2012, 03:00 PM
That would definately make me look twice...
  #68
Old 06-12-2014, 09:00 PM
86f150lariat 86f150lariat is offline
86f150lariat is starting off with a positive reputation.
Could you find a single cab short bed f150 frame an put the F350 axles under? Or no?
  #69
Old 06-13-2014, 07:17 AM
Quote:
F150 has coil springs and no provisions for the leaf springs
  #70
Old 06-13-2014, 09:03 AM
dangalli's Avatar
dangalli dangalli is offline
dangalli is starting off with a positive reputation.
Holy Thread revival Batman!
Where to buy new take of or used bed? BlueBeauty 1999 to 2016 Super Duty 4 06-12-2016 07:29 AM
From long to short Fordhoard68 1961 - 1966 F-100 & Larger F-Series Trucks 0 06-08-2015 05:17 AM
1964 long bed to short bed project questions SocialDistortionFan 1961 - 1966 F-100 & Larger F-Series Trucks 17 09-10-2014 10:36 AM
Short bed interchangeable with 8 foot? BlakePopovich 1987 - 1996 F150 & Larger F-Series Trucks 4 11-23-2011 11:50 PM
SRW Conversion to DRW for Short Bed? rljett 1999 - 2003 7.3L Power Stroke Diesel 30 10-26-2007 11:33 AM
Tags
1972, 1978, 4x4, bed, cab, conversion, f100, f150, f250, longbed, make, regular, short, shortbed, wheelbase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
