e40d 4r100 swap?
There is no 4R100 that will fit your truck. Ford changed the model names and many other parts when they switched to the 4Rxxx naming convention. There are numerous internal and electrical differences between the two that I consider them completely different transmissions.
There are good transmission builders that will use 4R100 hard parts to build performance E4ODs. But there is no true 4R100 with the correct bellhousing to fit a small or big block equipped OBS truck.
mrrish79
10-30-2013 07:46 PM
PRL
05-18-2010 05:17 PM
CT
11-13-2004 01:05 PM
