1956 F100 COLUMN OPTIONS - Ford Truck Enthusiasts Forums
View Poll Results: WHICH COLUMN DID YOU USE
FLAMING RIVER 3 13.04%
IDIDIT 6 26.09%
EBAY SPECIAL 4 17.39%
MID FIFTY "CLASSIC" COLUMN 0 0%
1956 STOCK 6 26.09%
OTHER: OEM SWAP FROM ANOTHER VEHICLE 4 17.39%
Multiple Choice Poll. Voters: 23. You may not vote on this poll
Old 10-14-2013, 07:47 PM
dynamic's Avatar
dynamic dynamic is offline
dynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to behold
So I am in the process of figuring out the parts I will needfor the Crown Victoria suspension swap and am starting to think about steering columns.
My truck will be running a 4.6 fuel injected engine from a 2006 crown with a 5 speed transmission from a 2010 mustang gt.
Basically I want a tilt column. Everything I read say 30 is the standard column for F100 projects.
I see everything from inexpensive ebay columns right up totop dollar columns.
What did you use?
Would you use it again?
FLAMING RIVER
IDIDIT
EBAY SPECIAL
Old 10-14-2013, 08:07 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Ididit plain steel (paintable) tilt column without shifter or ignition switch, Ididit steering wheel adaptor and Grant 15" wheel. Being able to tilt the wheel more vertical helps get rid of the "bus driver" lean on the steering wheel feel.
I'd definitely go the same route again.
I'd avoid the cheapest no name columns, some use salvaged parts for the tilt mechanism, the Chinese made ones use a lot of fragile plastic.
Old 10-15-2013, 12:54 AM
ben73058's Avatar
ben73058 ben73058 is online now
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Dynamic,
I made a mistake on columns. I started with an Ebay special that looked
nice & had tilt - I think it was around $230 if I remember correctly. When it came in the mail - a lot of the the pieces that looked chrome in the pics were just plated plastic. We tried to install it but the inside plastic parts were just crap & it basically fell apart.
So... We went with an Ididit column with Tilt the second time around.
Good luck over there.
Ben in Austin
1950 F1
Old 12-17-2013, 07:45 PM
dynamic's Avatar
Alright gang, so I have decided to go with an Ididit column.
Next decision is Chrome, brushed aluminum or polished aluminum
chrome is in the $500 dollar range.
brushed aluminum is in the $650 dollar range.
polished aluminum is in the $750 dollar range.
Can somebody give me the benefit of spending the extra money for brushed or polished over chrome???
Old 12-17-2013, 07:57 PM
56panelford's Avatar
56panelford 56panelford is online now
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
I like the painted IDIDIT columns
Old 12-17-2013, 08:57 PM
drptop70ss's Avatar
drptop70ss drptop70ss is online now
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Man you guys have money burning in your pockets! I stick with factory stuff from the boneyard or my own parts cars. I am using a 65 cutlass column, actual value maybe $75 with the steering wheel. Has a 3/4" round shaft on the end so easy to adapt to ujoints as needed.
Old 12-17-2013, 10:20 PM
Project-55's Avatar
Project-55 Project-55 is offline
Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.
Quote:
I'm with you drtop, I have a 87 van column that I cut down to 30" but am planning to use a crown vic column now to match my wiring harness, less than a c note in both of them. Or maybe I'm just cheap...hehe.
Old 12-18-2013, 08:06 AM
Branded Branded is online now
Branded is gaining momentum as a positive member of FTE.Branded is gaining momentum as a positive member of FTE.
The mid sixties tilt columns are demanding big money now days unless the seller doesn't know what he has.
Old 12-18-2013, 09:06 AM
Posting Legend
I feel better knowing that I'm navigating the highway with new parts than something 40 plus years old. I've picked up a few columns that the bearings were shot and the aftermarket ones look much cleaner.
Old 12-18-2013, 09:07 AM
drptop70ss's Avatar
Quote:
In my case no need for a tilt if I can set the angle up as I want with a straight column. I put tilt in my 37 buick and 48 cadillac and I never use it once the wheel is where I want it. I am using a straight column in my 51 F1.
Old 12-18-2013, 09:55 AM
AXracer's Avatar
I never change my tilt, but I sure like the comfort allowed by being able to set it where I prefer it, especially because I don't like the poor control the "bus driver" stance a straight column gives you. Especially useful when there was two of us driving our vehicles. I'm 6'2" 270, my ex was 5'4" and 110. Same with power driver's seat.
I also went with the painted column, I personally don't find them attractive enough to want to draw attention to it by blinging it up, but each to their own.
Old 12-18-2013, 06:03 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
If you get the natural finish and paint it yourself it seems to be a pretty good cost savings. Here's a link for Summit Racing at $369. The big guys (Summit and Jegs) have been offering free shipping on $99 and up orders.
http://www.summitracing.com/parts/id...0010/overview/
Dan
Old 12-19-2013, 10:10 AM
clintonvillian clintonvillian is offline
clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.
Does anyone here have experience with the summit racing columns? The one big draw for me to Ididit is the fact that they produce a kit that has your dimmer switch on the end of the signal lever.
Not a real big deal but it helps to remove the floor switch and keeps the dash cleaner.
Old 12-19-2013, 10:49 AM
old_dan's Avatar
That link I posted is the Ididit brand...it's just the plain Jane version with the ignition switch on the dash. I put this one in. It has the turn signal control and the hazard flasher controls along with the tilt lever. There are options with the high beam switch, but I'm using a classic floor switch. You do get the GM style connector. If you're using a new wiring harness it will have the matching connector for everything in the column.
Dan
Old 12-19-2013, 11:02 AM
How about the "summit racing brand column"?
http://www.summitracing.com/search/b...th-in/30-00-in
They are quite a bit cheaper, are they any good or junk?
Using local Aussie bits for my Effie Timmo Australia Chapter 1 11-20-2016 10:37 PM
Steering column and steering box change Cazman1955 1961 - 1966 F-100 & Larger F-Series Trucks 0 02-01-2016 06:12 PM
Steering column help slow2v 1961 - 1966 F-100 & Larger F-Series Trucks 4 06-26-2015 04:57 PM
1966 F100 power steering 66f100dvr 1961 - 1966 F-100 & Larger F-Series Trucks 6 02-15-2015 06:14 PM
55 F-100 and Gearhead column ungerp 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-26-2012 11:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
