Expedition 4X4 Probs
My 99 Expedition is having gem induced problems, I was wondering if anyone knows if I can replace it with one from an F-150, or an Explorer. Would this get rid of the A4WD and leave me with only 2h 4h and 4L, if so Im ok with that. Never really liked the Auto anyway. Thanks for reading and any help you can advice you can offer.
No, installing the switch will cut power to the front clutch and to the shift motor, but once you turn the switch on and the shift motor powers up, you'll be right back to where you are now.
Are you sure the problem isn't with the selector switch on the dash telling the GEM to go to 4L?
The way I understand it will go into 4L at 5mph or less and in neutral. But mine tried while pulling a friends camper at 40mph. Once I got it pulled over the grinding stopped and it locked into 4L. The 4X4 light on the dash was flashing but the switch was still in the A4WD position. It would not come out of low range until I restarted it but then it was still in 4H. I disconnected the shift motor and it went back to 2wd, even the hubs unlocked.
FarmLaw
1997-2006 Expedition & Navigator
141
11-14-2023 08:02 AM
cotten616
13
02-16-2021 08:35 PM
waalexander
03-05-2017 01:13 PM
ThatFordGuy
02-15-2011 07:44 PM
