WTB : Ford 400 flywheel for manual transmission - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Closed Thread
Old 10-14-2013, 12:14 PM
squarethumps squarethumps is offline
squarethumps is starting off with a positive reputation.
I need a flywheel for a 400 with a manual transmission.
I understand that the original part number is : D7TZ-6375-D which is for a 12" clutch.
and that the new part number is E5TZ-6375-H which is drilled for both a 12" and 11" clutch to fit both the 400 and the 351M motors.
I need either one of these flywheels.
Closed Thread
Stock Pitman Arm 79 Ford F150 4x4 greenmachine351 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-09-2015 12:30 PM
400 Flywheel fords/harleys Clutch, Transmission, Differential, Axle & Transfer Case 0 12-16-2014 08:26 PM
Number decode component build TBird Larry 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-16-2014 08:25 AM
I6 flywheel question ratrig Ford Inline Six, 200, 250, 4.9L / 300 4 07-09-2014 01:49 PM
Railfan G2G Tehachapi May 17 wpnaes S. California Chapter 30 05-17-2014 09:03 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
12", 351m, 400, clutch, flywheel, manual, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
