Help ID 3 speed RAB-Y
Hi First time poster here.
I recently bought a used 3 speed (3.03) to replace into my 1970 F-100 XLT 302 3 speed manual. The seller said it came out of a 1975 F-100. The trans has the ID RAB-Y.
The curious thing about this transmission is it appears to have a non-synched 1st gear. It grinds like hell unless you are at a complete stop. The original trans in my 70 had a synchronized 1st gear.
Questions:
1. is RAB-Y in fact from a 1975 F-100?
2. Does RAB-Y have synchonized 1st gear?
3.
Could the shift linkage be off enough to cause it to grind when down shifting into first when moving? Sure seems like an unsynchronized first gear.
Thanks in advance for all responses.
Questions:
3.
All 303s were all synchro, so your first gear synchro is probably worn out.
I don't find RAB-Y in any list, but that doesn't mean anything. Lots of HEF, RAT, RAN, and a host of others, so RAB could be in there too.
https://www.ford-trucks.com/forums/1...tion-info.html
Mostly they are all the same box, other than the two different ratio sets used. Case length, tailshaft housing length, mounting and shifter mounting holes, and possibly speedo drive gear, maybe speedo output location would be the variables.
RAB-Y 3 speed
realmccoy1978
01-15-2013 09:02 AM
Tractor Boy
27
08-03-2007 06:37 PM
FlaresideGlenn
05-30-2005 12:05 AM
ladogana2
02-17-2005 04:01 PM
