Project HodgePodge
Project HodgePodge
Well figured i would start my build thread finally. Been gathering parts for a little while now and finally have enough ill get started on it.
the truck getting the build is my 89 f350 CC 4x4.
a little history, the truck started out as a stock f350, non turbo e4od truck, since than had a shackle reversal, ZF5 swap, ATS 088 kit.
so the plan for the build is:
HE351CW Holset charger off of a 05ish 5.9l HO cummins
A prototype db2 pump from R&D IDI Performace
Electric lift pump setup that can sustain over 300hp
ARP head studs
Comp Cams valve springs
7.3L PS intercooler
R&D IDI Performance intake manifold
R&D IDI Performance stage 1 camshaft
R&D IDI Matched injectors
this will be put onto a stock bottom end with what i was told around 70K miles. Boost numbers are up in there air as of now, i will be closing down the factory wastegate on the turbo and running non wastegate with a drive pressure gauge to monitor pressure initially. The hotside is potentially a little small but wont know till it has been tried.
i have a lot of the parts already, just need to decide on a fuel pump for the set up. was considering a fass or a full return system with a walbro inline pump and a EFI to carb regulator I will also be eliminating the stock filter/head and going to 2 external filters mounted under the truck. Here is a pic of some of the parts. the other stuff IE gaskets, intake, turbo, ect is at the shop already.
Hoping to get a start on pulling the motor here really soon so i can get the motor busted down, head studs installed along with the new valve springs and get the intake all buttoned up so i can get the turbo/up pipes installed into the truck to fit pipe for downpipe and intercooler piping. Ill continue to update the thread as progress goes and try to snap some pics too.
ARP head studs
7.3L PS intercooler
Cool build man, this is exactly what I want to do to my truck...kind of a budgete build. The only difference is I was gonna run an HX35 or maybe a 35/40 hybrid.
Is that a 351 VGT your gonna run? If I heard right there's a non VGT 351 too.
And are those filter heads and filters from strictly diesel? I have been looking into a filter setup for when I do e-fuel. I found filter heads and Baldwin filters on strictly diesel, just dont know if theyr gonna work well with my setup.
I got the filter heads from R&D IDI Performance also.
I was going to go with a hx35 also but I found the he351cw more appealing for what I want. The he351cw is the non vgt variant of the turbo. The he351cw flows the same amount of AIT as the best hx35 so I figure it should be a good turbo for my application. I'll try to load up some pics of the turbo on my extra engine .
Rob
Rob
i have a tub full of 3" SS that a friend gave me i plan to use. should be minimal bends since the turbo outlet faces forward and the intake also faces forward. shouldn't be too tough.
still thinking on fuel, thinking about running both tanks with a secondary FSV from a GM that i would have to manually transfer the return to the tank im feeding off of. that we to alleviate having to swap to a sing tank and get the benefit of a dedicated return line from the regulator.
still have to find a air cleaner that will be able to handle the job and try to find some 4" SS for the intake.
Rob
Rob
