04 f250 died now won't start
10-13-2013, 12:10 PM
on
I have a 04 f250 that died while driving yesterday and now won't start. I replaced the batteries and alternator about three weeks ago. It will turn over just fine just seems like no spark. What could it be? Need to get this thing running.
10-13-2013, 12:19 PM
You can Unplug ICp sensor and try
But need the DTC Read and a Gauge for Live DATA
10-13-2013, 12:23 PM
on
Quote:
Originally Posted by
tcjhkbjt
If you're looking for 'spark', I'd say you're either in the wrong forum or you have serious problems.
10-13-2013, 12:54 PM
on
Thanks blade35, I new to the diesel world so where is the ICP sensor located. Should I try to start it with it unplugged,
10-13-2013, 12:56 PM
on
Friend of mine has a DTC reader, so what should I be looking for on the reader
10-13-2013, 01:12 PM
Certified Thread Hijacker
tcjhkbjt
Something that can read LIVE data, more expensive scanners can do it or:
Scanguage, DashBoss for iOS, Torque for Droid, Edge CTS, AE on a laptop etc is what you'll need.
Josh
10-13-2013, 01:21 PM
tcjhkbjt
Either under turbo
Or passenger side valve cover
We need to know its location to determine whether you have early or late 04 in addition to trying to start with it unplugged
10-13-2013, 01:24 PM
tcjhkbjt
ANy info helps
if you do find a DTC then that should point to the problematic system
Once your down to the faulty system then you will need Live Data from a Device josh mentions
Some of the Upper end DTC readers do show some live data so it will depend on what your Buddey has
10-13-2013, 01:39 PM
Here is a picture of the ICP on the valve cover of an 04. It is the sensor on the bottom of the picture. If you have it there, you have a "late" build 04.
on
He has Cen-Tech OBDII /EOBD
10-13-2013, 01:41 PM
on
amdriven2liv
Yes that is where mine is located, so unplug it and try to start it?
10-13-2013, 01:50 PM
10-13-2013, 01:56 PM
on
I did and it still didn't start
10-13-2013, 02:03 PM
on
Could be a high pressure oil leak internally, not building enough psi to fire the injectors, causing a no start. We really need some dtc info from you...
10-13-2013, 02:05 PM
STC fitting, hpo system, and/or cooked ficm are good places to start. Now, you need that live data.
