Changed Leaf Springs, Not sitting right
Hi Guys, I need your input. I changed out the leaf springs with flex end hangers to new leaf springs for non flex end hangers and used the DJM front hanger and DJM lowering shackles on the rear. Every thing went together well and it lowered the truck about 4". The problem is that one side sits lower than the other by 1".
All bolts are in same locations on both sides in relationship to hangers????
I may be able to raise one side by using a different mounting hole, but i shouldn't have to should I.
Need your input
Thanks for any and all input
Need your input
Thanks... I'd first loosen and re-torque the leaf spring cross bolts/nuts with the weight on the axle. I believe logging more miles on it will help it settle. It's fresh metallurgy and will likely need more cycling. Patience.
Per your post above, I meant the bolts through the leaf eyes - not the brackets. That is to eliminate the possibility of any binding due to tightening of the eyes and bushings while it was up in the air.
Go for about a 30-minute drive and "exercise" the new springs... drive plenty on street/roads with bumps and such.
You could try loosening the bolts on just the driver's side, jump on that side several times to see if the bolts/bushings will rotate some and re-tighten.
Is the front also off level? Could a weak front spring be the culprit?
Loosened Eye Bolts
I loosed the eye bolts only untill just snug. Went for a drive, went over bumps, railroad tracks. Still the same. Still 1" lower on passenger side.
I moved the rear hanger bolt one hole on passenger side and now equal height. Went for a ride, over railroad tracks, speed bumps..Still level
No aux Fuel tank, Nothing in Bed. Empty truck....I guess I'll watch it..Reason I changed springs as when I put my foot into throttle it felt the rear end was going to fall out. Now that is all gone and it's nice a firm...Is it possible that the frame is out. I'm running a 428cj with 450hp and 460 torgue
Last year I had to change out the Trac Loc differential as it wiped out all thrust washers and chews up some spiders. Been running open case for the last year with the passenger side doing the spinning. Rebuilding Trac Loc with new axle bearings now
Could I aslo have a bad shock????????
Shocks control the ride, don't really have anything to do with height unless you have those coil over shock type set up. Sounds to me like you have mis-matched springs that were sent to you. If you got it right then drive it for a while and see what happens. If it settles uneven then you may have to have the offending leaf re-arched or you may want to call the supplier and see what is up.
on
If it really bugs you to the point you can't live with it try switching them or find a spring shop and have the tested for unity. Back in the 80's had my rear spring re-arched to take out the sagging P-side with the camper on it hard to find a shop then.
Maybe just get some adjustable shocks to even it out on the lower side would be the easiest and cheapest way level it out....orich
ryans428
06-01-2005 08:31 PM
