tranny swap
tranny swap
hey guys need some help here I want to convert my 69 f100 long bed from 3 on the tree to auto I already have a reconditioned automatic column lined up to put in it what I need to know is can I just take the clutch pedal out without doing anything else or do I have to make huge modifications btw its a 300 cubic inch six thanks in advance
hey guys need some help here I want to convert my 69 f100 long bed from 3 on the tree to auto I already have a reconditioned automatic column lined up to put in it.
What I need to know is can I just take the clutch pedal out without doing anything else or do I have to make a minor changeover?
Trucks with A/T have a separate shaft (pivot pin) for the brake pedal to ride on. See 2A517 at left upper in parts catalog pic.
1968/72 F100/350: Brake pedal same A/T & M/T
You'll need this: C7TZ-2A517A .. A/T Brake Pedal Pivot Pin-5 3/32" long: 1967/72 F100/250 & 1973/74 F100/350 / Obsolete
KINSEL L/M in Beaumont TX has ONE = 800-816-2894.
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
NOS PARTS LTD in Waxahachie TX has TWO = 972-937-2201.
On the later trucks the clutch pedal arm is welded to the shaft, which is also the pivot shaft for the brake pedal arm. The clutch linkage is over to the right of the brake linkage, and the nut that holds it all together is on that side.
You can get this clutchless pivot pin from an auto truck in the junkyard.
1965/66 same as 1967/72 and 1973/79. Brake pedal rides on clutch pedal shaft.
One can get the pivot pin from a junkyard, but after taking it all apart...will the pin be any good...or not.
Nylon bushings (2474) wear, crack apart, pin wobbles on metal bearings that are made as part of bracket.
Meanwhile, back at the ranch, NOS is available.
zombiefied 247
06-02-2015 10:45 PM
jsnbuck
06-01-2013 04:13 PM
SonofaFord
09-30-2011 06:51 PM
