Front axle won't engage - Ford Truck Enthusiasts Forums
Old 10-12-2013, 07:33 PM
Austin J.'s Avatar
Austin J. Austin J. is offline
Austin J. is gaining momentum as a positive member of FTE.
I have a 2000 F-150 XLT Supercab 5.4 4x4 with the dash **** shifter. My front axle won't engage when shifting into 4x4. A few months ago the vacuum solenoids were replaced and they sound as though they are functioning properly. The diaphragm isn't moving the lever thing and i can't get the lever to move with a screwdriver either.
I know it has worked the past two weekends. Two weeks ago it was in a significant amount of mud and possibly submerged at times. I power washed everything pretty good immediately afterwords though and it has worked in between then and now. What could be going on?
Old 10-14-2013, 04:40 PM
Austin J.'s Avatar
Any ideas at all?
Old 10-14-2013, 08:50 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Does the front actuator attempt to move?
You know it has to and the collar engaged to get the front to lock up.
Where does it stop functioning and you have most of your answer.
If your going to off road it expect to have an issue now and then.
Learn how the system works so you can trouble shoot it for repair..
Good luck.
Old 10-14-2013, 10:19 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
Pull the vacuum hoses off and feel each one as someone shifts into and out of 4 x 4 (motor running).. If you have vacuum on both hoses, then the problem is in the slide mechanism or the vacuum cylinder. Tap on the arm and see if it has rusted or "stuck". Might spray some penetrant on the mechanism. Pry with a screw driver. Watch the cylinder and see if it trys to move (hoses installed) when someone shifts in and out of 4 x 4.... last move is to go internal.
Old 10-14-2013, 10:55 PM
Austin J.'s Avatar
Okay, I'll try and get the vacuum lines off when I get back home next weekend. I probably didn't troubleshoot as well as I could have, but I had engineering homework to do. I hope it ends up being a vacuum issue just so I have an excuse to install a posi-lok on it.
Old 10-14-2013, 11:59 PM
You still need the rest of the system working so the tranfer case engages the front drive shaft.
Good luck.
Old 10-24-2013, 05:32 PM
Austin J.'s Avatar
Sorry for long delay, but it has been thoroughly hectic with mid terms and I just found out my tools have been stolen. I have determined that there is vacuum on both lines.
Old 10-25-2013, 09:15 PM
steve(ill)'s Avatar
watch the cylinder and see if it strokes in and out... you may have to spray and tap on it with a bumping hammer or pry bar. might help to have one tire off the ground and have someone rotate it ? Not sure about internal pin alignment.
Old 10-25-2013, 10:03 PM
Austin J.'s Avatar
I know that it doesn't move at all while engaging and disengaging. I tried moving it with a screwdriver prying on it and it didn't move then. I'll go spray some penetrating fluid on it. I am getting new tires, so I'm having the guy look at it while it is on a lift.
Old 10-27-2013, 04:44 PM
Austin J.'s Avatar
I ended up not having the guy look at the 4x4, so I took at it again today. I got it working. It turned out that shaft on the actuation diaphragm was frozen up so bad that simply prying on it didn't move it at all, so after a significant amount of penetrating fluid and banging with some very large wrenches I got it freed up and it is moving properly now.
Old 10-27-2013, 05:20 PM
Amazing things happen when you look into them a bit deeper.
Good luck.
Old 10-27-2013, 05:25 PM
Austin J.'s Avatar
It took a scary amount of force banging on it to get it to work. I thought I was going to break something.
How to Troubleshoot and Fix F150 4X4 1997-2003 revytrucks 1997 - 2003 F150 125 01-31-2017 11:30 AM
1999 F-350 V10 4x4 transmission trouble 2011f350pearl Modular V10 (6.8l) 1 10-18-2015 06:43 PM
Transmission Won't Engage - Help blueheron 6.7L Power Stroke Diesel 17 08-30-2015 02:57 PM
85 F250 C6 Won't Move At First... rupert8 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 01-15-2015 11:21 PM
Front axle won't engage Texaswildman 1997-2006 Expedition & Navigator 6 01-31-2011 10:15 PM
Tags
4x4, fix, mud, offroad, solenoid, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
