Variable Deltas 20 to 0 back to 20 One trip
Early '04 CC LB SRW.
first off I PLAN on a Restore Flush next week then oil cooler replacement Thanksgiving week.
Main question- is there anything else that might be going on that I should be concerned about? Its my only vehicle and I wont be pulling anything until after cooler replacement.
Cruising:
EOT 208 +/- 2*
ECT 188 +/- 2*
When the engine is being worked (traffic, big hill, heavy pedal, any combination) EOT climbs to 225* avg highest ever was 240*. By time EOT hits 220ish ECT matches it and rises with it. The fan kicks in about ECT 220. ECT drops to 190 then rises to match again. Once the engine stress is over ECT drops rapidly back to 188-190. The EOT takes about 3-4x as long to get back to 206-210.
Thanks for taking the time,
Clayton
Cruising:
EOT 208 +/- 2*
ECT 188 +/- 2*
Clayton
The common and fairly easy for almost everybody to do method is:
with engine fully warmed up (ECT/EOT at least 190, give or take a couple of degrees) while cruising at 65MPH on flat highway - NOT towing.
Under load it's normal for both temps to increase and the delta to vary, typically once you "crest the hill" the temps come down quickly..
If you are doing the Restore and Restore Plus, make sure you do it BEFORE you swap oil coolers.
Here is the lengthy write up I did for it. It's very long. I'm looking at adding the backflush of the heater core and the oil cooler, but I'm still working on it. Obviously if you are changing the oil cooler, there is no reason to backflush it. I would spend a good amount on the radiator as well.
https://www.ford-trucks.com/forums/1...tore-plus.html
For anyone who isn't really convinced that the Restore is worth doing, here is a video of what WAS a clean yellow bucket with no trash in it. This is a sample of what came out of my radiator drain. I poured most of it into empty gallon jugs, and this was in the bottom, so I video recorded it.
And here is a photo of a clogged oil cooler. You think that's what I'm seeing in the bottom of my bucket? I believe it is.
the 20* spread is at cruising speed close to Misky's, for me 72mph is the sweet spot for my truck. which is why the oil cooler change is planned
Expy that thread is in my bookmarked for reference when I get to it next week. The cooler change will be a week or two after that depending on what my work schedule allows.
I'll be soaking and cleaning everything that is taken off (less turbo) thoroughly and repainting what is needed. Nothing will be put back on until its pristine again, I just like a good clean engine (inside and out) for a variety of reasons.
Well becareful About the HPO res and the cleaning Bit many of Folks with the IPR
Restore_Flush - YouTube
So again. In theory, my system was neglected by the previous owner and I honestly believe after seeing the jugs from my flushes, that I bought myself some time. I did the most thorough and time consuming flush except...I wish I had back flushed the cooler, just to see if my temps would have benefitted. Maybe I'm just fooling myself? Who knows. Time will tell.
I was at 7-10 before the flush and 7-10 after. No change. What I theorize is that my cooler health has possibly been extended by getting most of the junk out. I'm not convinced, after many hours of reading other owners back flushing that you could save one if these in a failed state. I have seen some owners with 40 and 50 deg temp difference get them down to 10-20. By then, its too late. The silicate and rust from neglecting coolant changes has really clogged the cooler at that point. Testing the anti-freeze is a must for maintenance.
Oh, so the picture of the oil cooler in your previous post is not YOUR oil cooler? you actually haven't changed your oil cooler yet? even with all of the stuff you flushed out of your system your deltas didn't change?....and what do you believe the stuff in the bottom of the bucket to be? or do you have a assumption? It's nasty looking stuff for sure. Also how long ago did you do the flush and what provoked you to do it in the first place? were you concerned with the deltas or were you changing types of coolant?......Sorry about all the questions but I have been asking them since I was a little guy It's how I got a lot of life's answers
Here is another oil cooler: (Again, not mine) but the color is the same...
And lastly, since I didn't post this in this thread, here are my gallons of draining. If you notice #9 (clear gallon) is a sample taken from my 5th Distilled Water drain and fill. It's very clear. The next day, I began my flush using Restore and look at the first jug (Green #1). That's just a 1 gallon sample of what was coming out. So you can count 3 gallon jugs that were all the same color. It was almost like I had never flushed the System.
In conclusion, all I am saying is that I believe I helped prolong my oil cooler by getting rid of as much cancer as possible. My guess would be that there are more owners who neglect their cooling system, than those of us who take care of them. With a little bit of luck, I'll be reporting back here next year that my EOT vs ECT is still 7 to 10 degrees. Heck, I know people who replace their oil cooler and still have the same spread as I have. Well, I'm all out of .
Benny, I used to work in a machine shop and occasionally I had saw duty where I had to work the entire day cutting aluminum stock. It looks to me like your saw created a lot of aluminum shavings that collected on the goop and covered it up. Did you use a fine tooth saw blade or what? It's hard to say... I have enough photos of oil coolers with that brown inside them that I'm ok with 1 or 2 that don't show it. There was a guy on youtube who posted a video of him back flushing the oil cooler AFTER he took it off the truck. I'm trying my best to find it. It looked just like my bucket X10.
Here's another good read... you were on this one Benny... It looks like he said the same thing, he had to cut it multiple times before he uncovered the nastiness. Do you still have yours? LOL
https://www.ford-trucks.com/forums/1...oler-pics.html
