S300CG? - Ford Truck Enthusiasts Forums
S300CG?
Old 10-12-2013, 03:01 AM
Tim Shultz Tim Shultz is offline
Tim Shultz is starting off with a positive reputation.
S300CG?
I have found a oil and water cooled S300CG Borg Warner. Yes, a water cooled S300. However, I cannot find ANY specs on it at all.
Its a Borg Warner S300CG part number 176488.
Also looking for info on two other Borg Warner turbos,
S200S057 pn RE515501
S2A pn RE508971
Any info or a place selling rebuild kits for any of these 3 turbos would be great!
Old 01-05-2014, 07:12 PM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
I did a quick search and came up with these items for you to browse through:
https://www.google.com/search?q=s300...ient=firefox-a
This link has your part number associated with it, so it might provide the info you need:
02-08 Caterpillar Military S300CG Turbo 176488
I found this for the S200S057:
https://www.google.com/search?q=S200...ient=firefox-a
And this for the S2A (RE508971):
RE508971 turbochargers, RE508971 turbo, RE508971 turbocharger, RE508971 diesel injection
I hope these help in some way.
Old 01-09-2014, 06:18 PM
turbonatorboyz's Avatar
turbonatorboyz turbonatorboyz is offline
turbonatorboyz is starting off with a positive reputation.
S2A pn RE508971
the s200S057 has a 57mm compressor wheel, and a john deere PN RE51501, same with the S2A, john deere PN 508971( the prevoius info states its for a 4.5l, so pretty tight)... the S300CG, identifies it being gated (G is gated, the previous info says it has an .80A/R turbine housing and its off a 7L, so best choice of the three) hope this helps...
89 F250 wHD 4wd ZF 5s42 swap. Xfer case Mhintlian 1987 - 1996 F150 & Larger F-Series Trucks 2 09-12-2016 10:32 AM
Injector and Turbo Cores alexk3303 Ford Truck Parts for Sale 12 12-22-2015 04:08 PM
Another S366 Turbo Question Thread nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 12 05-03-2014 09:53 AM
4spd NP VS borg Warner choptop49ford 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-05-2012 06:53 PM
borg warner turbo Fireman_dave Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-02-2011 12:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
