Adding oil & transmission treatment- over capacity?
I've got one bottle each of Lucas oil & transmission treatment, each about 1 quart. Right now, however, my engine oil and transmission oil are full to capacity, so I was wondering if adding the treatments would cause any over capacity issues? Or would the treatments be "absorbed" by the engine/tranny quickly enough that it won't be a problem?
Thanks.
Thanks.
Since TREATMENTS are meant to SOAK into seals, FILL scoring and scratches on cylinder walls, and STICK to engine & transmission parts to help prevent dry starts, it's not unreasonable to expect that a TREATMENT would, in fact, be absorbed to some degree by the engine, and would not have a long lasting effect on fluid capacity.
FLUIDS, on the other hand, are meant to be RETAINED by seals and provide lubrication. FLUIDS are not intended to condition seals or fill scoring on cylinder walls or stick to engine & transmission parts when the vehicle isn't running. So at least you were right about the fact that FLUIDS aren't absorbed by the engine.
So, is there somebody that can answer my question without being an ********* about it?
When I added Lucas to my transmission, I pulled over a quart out through the dipstick tube, and put less than a quart back in. Over filling transmissions can cause LOTS of problems. Its not hard at all to remove some trans fluid from the dipstick tube. In fact I didn't even go all the way into the trans. I had a suction gun, and switched hoses to a longer fatter hose, then it tightly sealed inside the dipstick tube and removed over a quart. This is a great alternative to dropping the pan. What a pain in the #$$. Think of over filling the engine being bad (or the trans for that matter) because there too much fluid and not enough space for air. Its always better to be at or just below the full line.
Trans dipsticks can be hard to read but you need to find the film on the dipstick. It will be a really light line. And it can only be found after its warmed up. Good luck man!
Hankster, I understand that on the surface, my questions seemed to be common sense answers. But here's the deal: just because I've spent a lot of time on this forum, does not mean that I'm aware of every little detail when it comes to these trucks. Most of my knowledge regarding engines has been self taught over the years and from places like this forum. I'm very good at having a particular part, tearing into the engine and replacing it, then reassembling without much trouble.
By contrast, I'm not very good at the technical side of things. I understand that overfilling engine oil can have negative effects, but I don't know how much extra oil it takes to cause problems. I know next to nothing about transmissions, so I had no way of knowing what overfilling them would do.
I apologize for my attitude and language, but I've been on this forum long enough to know that responses like yours tend to scare off newbies and people who aren't very educated about wrench work. Then instead of getting the answers they need, they get it from an unreliable source or not at all and end up making mistakes that cost them a lot of money and time that could have otherwise been avoided. That seems like a high price to pay because all they wanted was an answer to a simple question without being made to feel like a complete idiot because they wanted to learn something. I'm not saying there's no room for jokes and such on these boards, but if it's going to stop someone from learning more about their truck, IMO it's just not worth it.
What seems like common sense to you is not always common sense to everyone else. Not everybody that comes to this forum has previous experience with engines and it's actually very ignorant to assume that they do unless they say so.
Again, I apologize for my harsh words, and I thank you for the links. Thanks also to the others who responded.
That's funny.
Ow... it's so nice when we all get along . Now DBGrif, Whatever fluid you use will contribute to the total volume, so if you're going to use a 1qt of treatment then you need to take 1qt of oil or ATF from either the engine or trans. they won't soak into the seal, at any rate, if any of it works its way over the seal the quantity will be minuscule.
ill give you a real answer.
an extra quart in the engine will not cause you any grief, we're talkin an extra 1/4 inch of fluid level, not nearly enough to interfere with the crank. if overfilling with a quart of lucas oil treatment is the specific question, absolutely no harm will be done. the lucas will keep more oil in the upper part of the engine and slow its return to the pan (that's what its designed to do), further diminishing risk of crank contact.
now for the fun part: some of the stuff you said is funny, like fluid additives soaking into seals and metal components. however, anyone who tells you an extra quart in your engine is automatically bad news and "stupid" doesn't really have a clue why they are saying what they are saying, just flaming you for what they perceive as an opportunity to flame. flaming you for asking the question when they cant provide a competent answer backed up by facts (other than the manual says so) is pretty asinine. running an extra quart of oil would indeed be pointless (but not harmful) unless you had an oil temp problem. however an extra quart of lucas would be perfectly fine. a quart will not put you at risk of crank contact.
as for the trans, I wouldn't ever ownerfill an automagic. I mean, I would never own or overfill an automatic.
