AC clutch repair??
AC clutch repair??
I get my truck on the road and the heat quits. Great 20-30 out in the morning. So I open the hood at work to jump a truck and I notice the ac hoses are covered in ice. The AC clutch will not release. I pulled the clutch electrical connect to see if the relay is stuck. No still running the clutch is stuck. I tried a search but it ignores ac and clutch pulls up tons of stuff. (transmission)
Is there a way to adjust it?? Or just replace it? I never took a clutch off the ac unit before. It looks like I would not have to discharge it as long as I do not remove the whole compressor. Any tips or ideas??? Thanks
All you should need is a ratchet, 8mm socket(?), snap ring pliers and feeler gauges. You could try reusing the old shims or just trial and error to set the air gap (.018-.033 in). Can you get a thin screwdriver or a putty knife in there to try and separate the clutch from the pulley?
Assuming this is for the 1997 F-250 in your profile?
It has been on there several years. Not sure why it locked up. But I did have a belt shred a couple years ago. I can't see why that would lock it up now. But possible.
Thanks for the video, it answers some questions. I had a friend give me an AC tool. He said he will never use it. It looks like it locks into the holes in the pulley to hold it while removing the bolt.
Well this has been a bad week. I start off the AC clutch locks up... I take the other truck to work and it blows the exhaust off. I get home at 9pm and slide it back together and put a fair weld on it. I take it to work today running a little rough so I punch it and blow the freeze plug heater. At least I was close to home.
I go to take the bolt out of the ac clutch just now and I find metal shavings. Go gap at all in the clutch. I can't slip a knife blade in there. Hmm. Pull the front pulley and no shims under it. Do some looking and find this broken. Parts run. With 2 broken trucks.
Broken ac clutch
Broken ac clutch
Broken ac clutch
Broken ac clutch
Thanks for help all.
