Crown Vic swap & lowering link dump
So I've been researching & researching & researching the next major step on my F100 project and I thought that maybe some others might be able to benefit from my efforts. I have compiled a list of build threads, parts options, & magazine articles that add up to a plethora of information for anyone considering a Crown Vic IFS swap & a rear axle drop on their F100 (as well as a few other topics that might be of interest).
Specifically I focused on the 67-72 but I'm sure a lot of this information will help with other models as well. I apologize if this is a bit overwhelming but I'm sure you'll find at least 1 or 2 helpful bits of information in these links.
I will continue to update this thread as I gather more links & info. Also, feel free to add any additional links you think are helpful & I'll add them to this 1st post if I think they apply.
PLEASE! ONLY REPLY TO THIS THREAD WITH LINKS & HELPFUL INFO TO KEEP IT FROM GETTING TOO LONG.
Full Lowering Build
http://www.s10forum.com/forum/f30/64-f100-never-built-a-ford-492601/
http://www.fordification.com/forum/viewtopic.php?f=22&t=37897
https://www.ford-trucks.com/forums/1091766-70-f100-cv-ifs-tbird-irs-build.html
https://www.ford-trucks.com/forums/1172345-lowering-my-78-f150-and-crown-vic-suspension-swap.html
(the big one from carcrafter – tons of info, no pics)
https://www.ford-trucks.com/forums/716058-buildup-06-crown-vic-front-suspension-into-67-f100.html
CV Swap
http://www.fordification.com/forum/viewtopic.php?f=5&t=47610
https://www.ford-trucks.com/forums/showthread.php?t=1119894
https://www.ford-trucks.com/forums/1156498-crown-victoria-steering.html
https://www.ford-trucks.com/forums/1236153-77-f100-project-crown-vic-swap.html#post13084733
https://www.ford-trucks.com/forums/1172345-lowering-my-78-f150-and-crown-vic-suspension-swap-3.html
Step notch & 4-link
http://www.killbillet.com/showthread.php?36842-1953-ford-F100-on-bags
(parts)http://www.welderseries.com/blog/2010/05/new-product-step-notch-kits/
(parts)http://www.artmorrison.com/layout.php?y=store/&x=components
(parts)http://www.nfamusmetal.com/bag-on-lower-bar-triangulated-4-link-with-bag-mounts/
(article)http://www.classictrucks.com/tech/1209clt_c_notching_60_ford_f100_frame/
(technical info)http://jniolon.clubfte.com/drivelinephasing/drivelinephasing.html
Air Ride Parts
http://accuairsuspension.com/index.html
http://www.ridetech.com/store/trucks/
http://www.airbagit.com/
http://www.streetbeatcustoms.com/1969/Ford/F100/Suspension/Air-Suspension-Kits/
Rear Axle Technical Info
http://www.fordification.com/tech/rearends_ford05.htm
http://www.fordification.com/tech/VIN68.htm
http://www.fordification.com/forum/viewtopic.php?t=57672
http://www.enjenjo.com/9inch.html
http://www.jalopyjournal.com/forum/archive/index.php/t-62078.html
https://www.ford-trucks.com/forums/1252236-rear-axle-69-f100.html
Classic Trucks build articles
1.http://www.classictrucks.com/tech/0703cl_1968_ford_f100/
2.http://www.classictrucks.com/tech/0704clt_1968_ford_f100_steering_shaft_upgrade/
3.http://www.classictrucks.com/tech/0705ct_1968_ford_f100/
4.Missing article (you’ll have to order an old copy fromClassic Trucks).
5.http://www.classictrucks.com/tech/0707ct_1968_f100_bumb_side_build_off/
6.http://www.classictrucks.com/tech/0708ct_1968_ford_f100/
7.http://www.classictrucks.com/tech/0709ct_1968_ford_f100_bumbside_build_off/
8.http://www.classictrucks.com/tech/0710ct_1968_ford_f100/
9.http://www.classictrucks.com/tech/0711ct_1968_ford_f100/
10.http://www.classictrucks.com/tech/1001clt_1967_1972_ford_f100_custom_vintage_air_ac_ install/
11.http://www.classictrucks.com/tech/0801ct_1968_ford_f100/
12.http://www.classictrucks.com/tech/0802ct_1968_ford_f100/
13.http://www.classictrucks.com/tech/0803ct_1968_ford_f100/
Wheel well
http://www.classictrucks.com/tech/0901clt_1968_ford_f100_nation_parts_depo_fender_wh eelwell_install/viewall.html
A/C
http://www.classictrucks.com/tech/0912clt_1967_1972_ford_f100_vintage_air_ac_install/
Door hinges
http://www.classictrucks.com/tech/0804clt_door_hinges_the_bumpside_build_off/
<oHIO Silver's Technical Info Hyperlinks</o
<ohttps://www.ford-trucks.com/forums/1...mpilation.html</o
Full Lowering Build
CV Swap
Step notch & 4-link
Air Ride Parts
Wheel well
A/C
Door hinges
Found a CV IFS & Mark VIII IRS build thread for an older F100 that doesn't directly relate to our 67-72s but it does provide some additional ideas on how to use air ride suspensions that y'all might find helpful.
The FORDification.com Forums • View topic - 59 SWB 32v 4.6 5speed CV front Mark8rear on bags
JEFFFAFA
19
05-08-2015 06:25 PM
