1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
GVW of a 2008 SD
Old 10-11-2013, 08:29 AM
Dogmann's Avatar
Dogmann
Dogmann is offline
GVW of a 2008 SD
Anyone know the GVW of a 2008 F350 CC SRW super duty with V10?
Old 10-11-2013, 10:50 AM
Chalkie's Avatar
Chalkie
Chalkie is offline
You mean it is not on the driver side door post?
Old 10-11-2013, 12:23 PM
senix's Avatar
senix
senix is offline
Received 1,400 Likes on 997 Posts
Door cert will have limited info, mostly pertaining to the truck itself. But more info is here:
https://www.fleet.ford.com/towing-guides/
Select 2008.
Old 10-11-2013, 04:57 PM
Chalkie's Avatar
Chalkie
Chalkie is offline
If my original response seemed somewhat curt my apologies. I didn't see that the OP was asking about towing and the only mention of GVW I saw in the charts was that it was base curb weight + cargo + passengers. The door sticker shows the GVWR which the weight that should not be exceeded. The chart is excellent for determining the max trailer weight and GCWR. In any case, it takes a scale to get an accurate answer to any of that.
Old 10-11-2013, 05:52 PM
senix's Avatar
senix
senix is offline
No I think you got it right but on the chance he was thinking towing numbers I though that would be helpful.
Old 10-11-2013, 11:28 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
If I'm reading the original post correctly, he's looking for the base curb weight. This is also on the B-pillar of 2008's. It'll show a GVWR and then have a number that says something like, "weight of passengers and cargo should not exceed X". If you subtract that X from the GVWR you will get the weight of the empty vehicle (GVW).
Richs66
2009 - 2014 F150
08-10-2019 07:49 AM
duke7595
01-01-2012 01:16 AM
coolmc11
02-03-2008 10:48 PM
pickup_289
11-01-2006 05:03 AM
Thomas A
10-30-2005 02:35 AM
Quick Reply: GVW of a 2008 SD
