Fixing Flexplate 2000 Excursion 4x4 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 10-11-2013, 02:03 AM
Mitchell_Texas Mitchell_Texas is offline
Mitchell_Texas is starting off with a positive reputation.
Hey guys, can i get some tips on to fix the flexplate on a 2000 ford Excursion.
Here is the details:
2000 Ford Excursion
110,000 Miles
V10
4x4
I am positive that the flexplate is bad. My friend and I are planning on doing this on saturday. Any tips to speed up the process would be grealty appreciate.
Old 10-11-2013, 02:43 AM
MURDOMINO MURDOMINO is offline
MURDOMINO is gaining momentum as a positive member of FTE.
Since my first engine replacement without removing the trans was on my 4x v10 excursion, id have to say it was pretty easy. I am used to pulling transmissions ans t-cases though, and with the height and weight of both, i would probably just pull the engine and be done with it.
Old 10-11-2013, 04:22 AM
housedad's Avatar
housedad housedad is offline
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
Quote:
Except you now add in the expense of air conditioning recharge, Coolant refill, a new oil cooler (Required by Ford Per Shop Manual to prevent engine damage) and doing loads of additional work that you did not have to do just to pull the trans. You STILL have to do the same amount of work to get that trans out of thereif you find anything wrong with it.
Flexplate and Tailgate 4x4ford33 WTB - Parts & other 2 01-13-2014 09:33 AM
E4OD keeps breaking flexplates mattsautobody442 1994.5 - 1997 7.3L Power Stroke Diesel 17 11-21-2013 08:56 PM
71 302 to 93 AOD flexplate? Schmitty 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 09-12-2013 01:29 AM
1993 IDI flexplate Bigdaddybendog 1987 - 1996 F150 & Larger F-Series Trucks 2 05-28-2010 02:31 AM
Flexplate E4OD davisrats 1994.5 - 1997 7.3L Power Stroke Diesel 31 04-29-2008 10:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
